View Poll Results: How old are you?
20-30 12 3.29%
30-40 33 9.04%
40-50 84 23.01%
50-60 143 39.18%
60-70 71 19.45%
70-80 21 5.75%
80-90 1 0.27%
90+ and a legend! 0 0%
Voters: 365. You may not vote on this poll
Old 02-28-2017, 03:51 PM
unruhjonny's Avatar
Originally Posted by RocktimusPryme View Post
Im fairly certain I saw a 455 in one years ago. But it didnt fit all that well, I think he ran it without the hatch.
I actually almost did that SC 3800 swap. I even went so far as to secure an engine that was a target of opportunity. Problem I ran into was when I tried to buy a Fiero. The only ones I liked were the GT models in the last couple years or production. And people are pretty proud of those price wise.
From what I read it was a pretty easy swap.
HPP had a geeat article on one.
I personally prefer the Quad4HO swap - but I am admittedly bias.
Putting a Quad4 in a Fiero in either LO or HO trim would be lighter than either original engine, and have more hp to boot!
I had actually read that the Quad4 was slated to replace the Iron duke for 1990 Fieros... that would have been a game changer (at least until the automotive press whould have given the Quad4 a bad rap for the OE head gasket issues)...
https://youtu.be/uzHjPuB-7N4
(in the video you can spy my '73 Firebird parked infront of the Grand Am.)
1970 Formula 400
  #202
Old 03-01-2017, 01:11 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
The Quad 4 is good if you can keep the head gaskets from blowing and the timing chain on the sprockets. JMO.
The problematic water pump was normally the culprit for both.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
  #203
Old 03-01-2017, 11:45 AM
72projectbird's Avatar
24. Probably one of the youngest members on here.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #204
Old 03-01-2017, 02:21 PM
pontibeast's Avatar
pontibeast pontibeast is offline
Just think of the tech improvements you will see in your lifetime. I am close to 50 and cars have come a long way from the leaded gas car technology of the 60's and 70's. You will be driving your flying car one day bitching at some young kid that you remember when cars ran on gas and not tap water.
  #205
Old 03-01-2017, 02:28 PM
1973ramairman's Avatar
1973ramairman 1973ramairman is offline
Double nickels
  #206
Old 03-01-2017, 09:07 PM
unruhjonny's Avatar
The head gasket issue is fixed with a modern felpro style gasket - not an OE (victor reinz) gasket...
i haven't had any issues with a water pump...
timing chain problems are typically because the chain was worn out, not set properly, or the tensioner crapped out...
1970 Formula 400
  #207
Old 03-02-2017, 12:07 AM
STEELCITYFIREBIRD's Avatar
Someone showed up with a modded quad in a 4 cylinder fwd stock car and ran lap times comparable to a 2300# 400HP V8 powered tube chassis car, I was impressed as were most that had a watch on it. That thing sounded like a chainsaw! This is the grass roots of circle track racing youth ingenuity.
  #208
Old 03-02-2017, 12:14 AM
1972 Formula 400's Avatar
1972 Formula 400 1972 Formula 400 is offline
26 years old. Already trying to hold on to my youth!
