Old 11-21-2016, 11:48 AM
PontGuy's Avatar
PontGuy PontGuy is offline
As others have said make sure that your rubber fuel hoses from the tank are all in good shape. I remember once having this problem too, on another car. But that one would not run at all with the broken hose.
Crank it for 5-10 seconds, then see if you get a pump shot. If not then replace the fuel pump.
I meant that you should check to see if you get an accelerator pump shot by looking into the carb and stroking the throttle. Not sure that loosening the inlet connection is as good a way to check.
Both a cracked fuel hose and a bad pump can cause the same symptom- no gas gets in the carb when cranking.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
Old 11-21-2016, 02:03 PM
skipp65 skipp65 is offline
Originally Posted by zeebo View Post
im gonna say a little bit about what we found with my friend's California sourced chevy nova...ran and drove fine..if it sat more than a couple of days, you could not get it started without pouring gas down the carb. after that, ran fine. well to spare you all the swear words and labor, come to find out it was the rubber fuel lines were dry rotted---not enough to leak; but enough to suck air at the top cracks that the fuel pump couldn't prime. we replaced the rubber lines at the tank and up at the fuel pump. car started every time after that.
I've experienced this a few times
Old 11-21-2016, 05:51 PM
carbking's Avatar
carbking carbking is offline
For several years I have contended that the old updraft carburetors (used prior to 1930) were much more reliable than the modern downdraft carburetors.
Why??? They were so hard to get to, generally the REAL PROBLEM was diagnosed and repaired before the carburetor was touched
And Cliff, the foam pads actually did work, as least in the mind of some of the "mechanics" (nowhere else).
Jon.
Old 03-11-2017, 04:30 PM
carpoor carpoor is offline
The fix ended up being a different choke rod and box. I picked one up for a 68'-70' from the parts place. Had to tweak the rod slightly. Works like it should now. Also found a loose distributor cap. (My father takes the blame for that one)
1972 Chevelle SS 2dr hardtop 454 LS5 4 spd - "Pure Stock"
1969 Chevelle 2dr hardtop L72/M20 - my "retirement" project.
1968 Chevelle 2dr hardtop 6.0/80E - pro tour-ish
1972 Monte Carlo turbo 6.0/TH400
2001 Silverado RCSS LQ4/80E swapped, cam, headers, FBO.
1972 E lCamino SS AFR headed 454/TH400 - the old man's project
