Car is looking fantastic. Congrats to you and Robert for the fine work. The paint blending is great as is everything else.
Looks great. You're lucky to have a good paint / body guy locally to do the work.
It looks like Gardner MAY have sent you the '71-'73 chrome tips. I would double check before installing them. The '74 / '75 tips are longer. If they are the earlier tips, they will be too short (just trying to help, not being critical). |
Here's a pic from an ebay auction to show the difference (74-75 tip on top, 71-73 on the bottom):
BJ
1971 GTO 455 HO 4-speed - Cameo White, White Vinyl Top, Jade Green Interior, Ram Air Hood, AC, Honeycombs and 8-track 1974 Formula 455 I Owned in 1975-1976. Now Own Its Twin From Same Dealership |
BJ
I'm impressed with the progress of the car. I am also impressed with the packaging of the exhaust. Surely, it will fit the car, unlike some systems on the market......
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 ![]() 2019 Canyon SLT Crew 4X4 ![]() |
Here's a couple of pic's of my Original paint 74 Formula. Hope it helps.
How are your head pipes from Gardner configured? One piece off the manifold, or two piece with the manifold elbow needing to be welded after installation? I just installed the 2 1/2''Gardner system and had to weld the elbows after the system which is no big deal, but after the install I was thinking that the elbow looks pretty restrictive.
The Gardner systems are an exact duplicate of the original ones - with the same original flow restrictions and all.
If you are looking for performance, go aftermarket like a Pypes system. If you are going for restoration go Gardner. I have had the Gardner systems on two 455HO 1972 Formulas and they looked perfect on a full restration but I went with a Pypes crossflow on my Gramma's car with their new 2-1/2" Ram Air D-port manifolds, and that exhaust completely out performs the stock/Gardner system in terms of performance. |
cool!
Thanks for sharing that letter and pictures!
1974 used Guide Power Beams, such as these:
Steve,
I did something similar except I took a Gardner Exhaust off of my 72 455 HO GTO and put on a 2 1/2 R.A.R.E. X pipe set up on and what a difference,like night and day. The motor can breath. |
Guides - those halogen units can easily push it towards the pro touring look.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
Nice Find! Thanks.
BJ
Interesting find. That explains the problem with my 73 SD455 Formula. The original owner ordered both the stripes and the side moldings on his order form. Due to the conflict, both selections were deleted from the car further up the paperwork chain when it was submitted.
Here was a picture I snapped of the '74 a while back.
Here is a pic I took while it was still in wrapper - may be off by a half inch or so.
![]() Eric Gardner assured me that I have the right length, that he knows there are two lengths and that I have the right one. I'm having to go on his assurance here. Looking at my photo, it may actually be closer to 15" BJ
Exhaust manifolds arrived today from Central Connecticut Coatings.
![]() ![]() ![]() ![]() ![]() I'm told by Eric that there is no gasket needed between the down pipe and the manifold - just metal-to-metal. His down pipes came with a nice ceramic-coated flange - two-bolt on left and three-bolt on right. Getting installed this Friday. BJ
Tips look like the correct length.
Are those Max Performance manifolds??? Are those lines on the end flanges from where they hung to coat? |
Thanks Mike. I bought them from Ames. Which lines are you referring to?
BJ
