Old 03-28-2017, 12:30 PM
Default Engine tranny weights
So for you IA2 E head guys -got a weight +/- TH400?
Old 03-29-2017, 01:37 PM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Interested as well...
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 03-29-2017, 01:51 PM
Steve C. Steve C. is offline
Th400 transmission weight. According to one source an average unit tips the scales at around 135 lbs. with a whopping 55 lbs. of internal rotating weight.
Old information here:
Old 03-29-2017, 02:06 PM
Hard to say!
The difference between the weight of a 13" converter and 8" is a good amount, no?
Old 03-29-2017, 03:54 PM
Another source...
We have weighed several different Turbos and the weight ran all over the place. The stock T-400 we had in my son's car originally, weighed 139 lbs., the beefed up T-350 was 119 lbs., I have a friend that has a T-400 with all the lightweight parts and it is 122 lbs. The T-400 we have with the huge 36 element sprag and special lightweight drum is 134 lbs., and lastly, the tougher-than-nails ATI superglide with the heavy duty case is 109.5 lbs. with the 10 clutch drum.
All the weights posted were dry, and minus the torque converter
Don't know about the fluid
Old 03-30-2017, 12:40 PM
Frank from All Pontiac replied to me a dress out motor they use 650 lbs fro shipping weight and no freight have adjusted that.
Yea this TH 400 is a little heavier than I like to pick up by myself anymore! It has a heavy aluminum pan also. TH 350s not so bad. The 200 R I have is kind of heavy also.
just trying to get a ball park difference than the iron head SBC scattershield, ST10 they are replacing. I have 440 for a iron head SBC , aboput anther 70 for my light flywheel clutch and scattershield. Seen ST-10 weights all over also.
Old 03-30-2017, 02:09 PM
Richmond lists their replacement ST-10 at 70 lbs. So looking like a 200 lbs difference.
Old 03-30-2017, 09:37 PM
Half-Inch Stud Half-Inch Stud is online now
..wait until you get a load of the 4L80 without the Converter. Then with the stock converter.
Old 03-31-2017, 01:30 PM
JD311's Avatar
JD311 JD311 is offline
love pulling those out of the pic a part yard in the mud with hand tools! Gonna have to weigh some transmissions now lol
