#1301
TEST
#1302
Tom,
What is considered "high pressure oiling systems"? The titan oil pump is currently set for 95psi. Thanks, Ed
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
#1303
I would think this level of performance would demand a dry sump system.
#1304
Why?
#1305
It will get difficult to keep a wet sump pickup covered with oil at both ends of the tracks if you run in the 6's (roughly speaking).
If your bearings show distress, don't be shy about raising your oil pressure. Rodney and Travis run something in the 125-140 psi neighborhood. Especially watch your rod bearings. If they run too dry and spin bearings, it will tear rods loose. Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
#1306
Listen to the man!
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
#1307
Dry Sumps have many advantages over a "WET" Oil system.
Very Fast Street Car with today's Dry Sumps can live on the street for a long time. Porsche Cayenne has one stock, Ford GT Has one stock, (did not say Mustang). Marty ran one in 1996 (FOR A REASON). You really have to "cover all of the bases", not just slap some turbos on a engine and call it good if you are running quick times in drag racing. Road Race cars, (except the street type stuff or Hobby stuff) typically run a dry sump for better oil control and also for SAFETY. The basic systems should be covered before the other parts are added or at least designed into the basic package FIRST. Not as a afterthought when the stuff you used does not work. Then you are just doing "DO-OVERS" Bob and Frank did a killer Dry Sump system for a Pontiac (VERY PROFESSIONAL DEAL) THEY MAYBE SOLD A HANDFUL OF THE SYSTEMS TOTAL). Sad. Tom V.
#1308
I love the simplicity of a wet sump. Grocery Getter was fine with one into mid-7's and we tried it on funny car but it let us down.
Eric
#1309
The Parts Ed is putting on his car reflect a 6 second capability.
Food for thought. Tom V.
#1310
Leech told me he had to go dry sump at the RPMs he wanted to run. Either that or a lot of time. effort and risk making a pan with serious baffles.
Shifted @8,800 and crossed the line 9K+ I believe. Out of E heads with stock valve location and stock E guides. Safe to say they were maxed out. I have L jacks old E heads done my Gabby. Flow 408cfm. Mikes went 414 (and Marcella with tell you cfm is only 48% of the answer, I believe him) Gabby told me the heads will pull to 7500 with a 535 and 7800 with a 505. Almost the same cfm and Mikes heads had 1000RPM more "pull" to them with a 565 no less. Tells you its all about the combo. That and 18-1 and a BOP with a ton of work done to it. Anyway, might want to consider dry sump. |
#1311
Build yourself the whizziest oil pan and baffles you can dream up. Put it in your hands full of water then slosh it as hard as hope your car will launch. You might want to wear waders cause your gonna get real wet. now imagine all that sloshing oil gets into a spinning crank and gets thrashed and whipped into a froth. Scrapers help but they are an indirect route to the pickup.
I ran tricked out wet sumps with accusump backup, but they were marginal at best. Put a dry sump in it and forgot about it. Dude you are building one of the coolest badboy Pontiacs out there. You'll be launching and initial accel at 3G's Don't go cheap here. Too risky for your engine, your car and your safety! Good luck with your car, It looks amazing! |
#1312
If you "have" to go dry sump, it's because you have other issues inside of the oil pan...
#1313
There you go have Langer build you an oil pan!
#1314
Stan
#1315
Dry Sumps take more hp typically from the engine but have other benefits as mentioned above. Not everyone is a John Langer, especially in the Pontiac World. Tom V.
#1316
It is not just the oil pan. It is also how you drain the oil back, bulkhead mods, crank mods, bearing mods etc...
#1317
P/S, F1,IRL and Comp run dry sumps. Even Big Chief! They all have the mods done to every component. By the time you add external drain backs you've paid for some plumbing for your drysump. You can size the pressure stage to your needs. The scavenge sections do not make any appreciable psi so they add negligible loss. How much more power do they take? Not much, you can prime your engine with 1/2 hp electric drill motor.
#1318
Good Info from everyone. Thanks
#1319
Stan
#1320
Yes 5% of the engines cid in pounds. It isn't worth the weight for the added hp. Additionally it isn't worth the additional 50+'pounds on the nose.
