With some sticky tires should be a fun track car.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
I got the subframe connectors in,the Konis came yesterday,getting ready to order tires and wheels,need to get a shoulder belt system in it.Hope the 8.2 does not break.Joe said my hemi NASCAR holley with lemans bowls made as much HP as his dyno carbs.Doubt I will get my chit together before it gets too hot to go to Fontana road course.Tom
Tom,
What series are you going to run in ? Of interest here..... but not meant as a omen ![]() https://www.youtube.com/watch?v=P_wFAdTroac .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
I would sweep the camshaft position and find the sweet spot that the engine likes vs what people assume as the parts have never really been tested on a basic #48 head with no porting that if lucky might go 205 cfm. Stock RA-IV would be 220 assuming 25" of head testing pressure on the flow bench.
Steve,just track days,no racing!Old farts driving!Tom
this is the last pull,Joe backed it 3 degrees(one crank keyway)Lowered the pumping 6-7 lb.He started the pulls at 36 and kept retarding till he ended with 31 degrees with no loss of power?Joe said we left a lot of HP on the table with castiron exhaust,no spacer on the HSD intake and no 1.65 rockers.It liked my 850 NASCAR Vac sec Holley.
All I know about road racing is that I love to watch it. So I'm wondering what you use for braking. I'd imagine the stock system wont hold up on the track.
Karl
The car has Baeir on the front and stock drums on the rear.Im going to get the complete system checked out before I hit the track.As I said before im not going to race other cars,just me and the clock.They have track day where you get I believe 20 min at a time on the track.Tom
Power curve looks nice, flat down low and holds on pretty good up top too. |
Tom Porterfield has some improved compound drum shoes.
The engine with the SPII made 434 and not 234 with the dual plane.Fat fingered.Joe made 12 pulls on the engine.Best number was 449.3HP@5800 with the HSD.Tom
Those are some nice numbers for stock heads and manifolds.
Just wondering what it might do with some 290cfm KREs. The exhaust would be the choke point for sure with those but it would tell us if the current heads are holding it back. When I win the megamillions I'll buy you a set of heads if you'll dyno test them back to back... ;-) is there any way you can get any kind of spacer under the carb? Even a 1/2" would probably help.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
I did that engine but with the road paver cam.It made just under 600 with a 2-4 setup on it.If I can find it I will PM it to you.Tom
On its way Will.Tom
Those FAST guys massage the heck out of factory exhaust manifolds! Gessler used to do a lot of my Buick buddies manifolds and I think he does Pontiac manifolds.
And the intakes!Tom
#38
I think Greg retired a couple of years ago.
#39
Thanks Tom! Read through the post you sent and don't see anything abut iron manifolds and it was a considerably larger cam.
I'm just curious about the particular combo in this post, especially the stump puller with iron manifolds. Would the engine pick up significantly if you changed the heads and nothing else, or is the exhaust choking it too much?
#40
The heads would help some for sure,the cam IMO is small for 455 and 290 CFM.Tom
