If that doesn't work: Use Permatex's The Right Stuff and finally be done with this. It will fill-in any pits or mis-matches and seal. I used it on my son's S10 thermostat housing that had a bad nick in one surface, and it has worked great. Use it instead of any other gasket, and I would always let it dry overnight before I added any fluid. Also, make sure you use it inside and outside the bolt holes.
Rick |
