Old 06-09-2017, 02:15 PM
Cardo's Avatar
Cardo Cardo is offline
Smile Saving a 1965 ..... Lemans?
We have lift off. Finally getting to start restoring my Lemans. Previous owner started to clone to a GTO, taking it back and keeping it a Lemans, just because you don't see too many these days. Let the restification begin.
The Following User Says Thank You to Cardo For This Useful Post:
Old 06-09-2017, 04:48 PM
1_Wild_Cat's Avatar
Excellent....Good luck with it. It looks pretty solid.
BTW - I wish I had a lift like that....color me green.
Old 06-09-2017, 05:09 PM
Jeff Hamlin's Avatar
No need to justify keeping a LeMANS, besides they were here before the GTO
Best of luck with the project.
Old 06-09-2017, 05:16 PM
Chris65LeMans's Avatar
I did it. Have fun with it - you're right about their rarity: I'm usually the only '65 LeMans at all Pontiac shows, even.
Old 06-10-2017, 01:54 PM
Cardo's Avatar
I found a really nice car to start with. Florida car, PO had the car stripped and metal work mostly done. It only needed a trunk pan, floor pans only where your foot sits, and both glass channels which was done when i got it. All in all they had alot of the hard stuff done, but hey had welded up every single emblem and trim screw or clip hole. So after i get the frame blasted, i will put the body on the rotisserie and start finding the rest of the holes and drilling them back out. Engine wise, I've found a 389 from a 65 that will be finessed a little and installed along with a 200r4 overdrive and some 3:55 gears. It's a factory air car, so all of that will be going back in too. I'll have plenty of tech questions for the experts, as i bought the car home in boxes. I restored a 66 GTO 20 years ago, so I've got a pretty good idea how this goes, but they're all a little different so i'm sure i'm going to need to buy a vowel of phone a friend multiple times.
Old 06-10-2017, 02:28 PM
beertracker's Avatar
beertracker beertracker is offline
Good luck with the restoration. To clone or not clone? I had the same choice to make with my LeMans and chose to keep it LeMans since the VIN number gives true identity. bt
Old 06-12-2017, 02:06 PM
tripower's Avatar
tripower tripower is offline
Nice to see! After all, what looks better than a 65 Pontiac A-body vert? What are your plans for paint and drivetrain? Best of luck and please keep the pics coming along the way.
Norm J
Old 07-11-2017, 10:14 AM
Cardo's Avatar
Been busy the past month. Trying to get the frame into paint so i can get the body onto the rotisserie and free up the lift. Should be painted by the end of the week.
ID:	458542   Click image for larger version
ID:	458543   Click image for larger version
ID:	458547   Click image for larger version
ID:	458548   Click image for larger version
Old 07-11-2017, 10:16 AM
MDGOAT69's Avatar
MDGOAT69 MDGOAT69 is offline
Looking good! Nice work!
1979 Trans Am: Y84 WS6 400/4spd
1967 YS 400, 670 heads, Summit 2802 cam, long tubes, ST-10 trans. McLeod hydraulic clutch conversion.
Old 07-11-2017, 10:19 AM
Cardo's Avatar
Primer
ID:	458550   Click image for larger version
ID:	458551   Click image for larger version
ID:	458553   Click image for larger version
ID:	458556   Click image for larger version
Old 07-11-2017, 11:36 AM
tempest1964's Avatar
Rich, I will be following your build closely. And, PS, I got those rubber plugs Monday. Thanks again.
Tony
Old 07-11-2017, 01:02 PM
Cardo's Avatar
Hope they are what you need Tony. Do you still need fuel line pics? I took several before i took this apart.
Old 07-11-2017, 01:06 PM
6567GTO's Avatar
6567GTO 6567GTO is offline
Sweet, good luck. Glad that you're keeping it a Lemans!
_________________________
Sonny Barger
Old 07-11-2017, 04:44 PM
I think I'm okay. Ordered 3/8 supply and 1/4 return from the Right Stuff along with clips. Should arrive early next week. If I get stuck, I'll let you know. Your frame looks sweet. Is that powder coat?
Old 07-11-2017, 04:54 PM
Cardo's Avatar
No. Actually that's just the primer. I will be painting it tomorrow. It is the Eastwood Epoxy primer. Paint will be the Eastwood Extreme Chassis paint with the ceramic in it. I'll post a couple pics of that once it dries.
Old 07-17-2017, 08:01 PM
saltman 1965's Avatar
saltman 1965 saltman 1965 is offline
Looks good. Nice to see another Lemans not cloned. After Cruisin The Coast this year I think I will tear mine all apart and do the same. Keep us posted on your progress.
1965 Lemans Vert
1968 Shelby GT 500 KR
Old 07-18-2017, 10:08 PM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
Frame looks great Cardo, but I think you're going to need more washer fluid to finish the car.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'65 GTO Hardtop, restoration ongoing
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
Old 07-19-2017, 06:19 AM
Old 07-19-2017, 06:24 AM
Cardo's Avatar
Lol! You caught me... on sale for 48 cents a gallon... couldn't resist. There's 8 more gallons on the other side of the garage.
Old 09-04-2017, 03:44 PM
Cardo's Avatar
Still plugging away.
ID:	462658   Click image for larger version
