Old 05-30-2017, 11:23 AM
Bentwheelbob's Avatar
Well, the steering column is now done and back together. All in all it turned out well. I painted it with SEM Trim Black Euro Jet Satin. It matches the paint on my '73 TA pretty well, maybe just a little more sheen. I tried to save the one sticker on the column, but unfortunately it partially peeled off when I removed the masking tape after painting. Also, I am not happy with the repro tilt lever. If anyone has a pristine original please let me know. Here's a few before and after pictures.
  #1202
Old 05-30-2017, 12:26 PM
77 Canamman's Avatar
The tilt lever is GM 9787072. Plug it into Partsvoice. Several come up. I bought one at the dealer about 5 years ago, but they are now discoed..
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #1203
Old 05-30-2017, 05:26 PM
Thanks for the heads up. I've got two ordered and will keep you posted. They were priced at $10.00, but when I said I would take two of them she knocked the total to $15.00 shipped. Hah. They had three, but she said the third was a little shelf worn.
  #1204
Old 05-30-2017, 06:02 PM
That's a great price. I hope the quality is acceptable. I bought one on E-Bay a year ago for $25, and the one purchased from the dealer 5 years ago was $15.
  #1205
Old 06-01-2017, 05:31 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Hi Bob-
Looks fantastic as always! In your last picture did you have the gold colored bolts plated, or where they spray painted?
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #1206
Old 06-01-2017, 05:36 PM
Judge273's Avatar
Judge273 Judge273 is offline
I think theyre copper? Mine polished up nice?..
Mike/Illinois
  #1207
Old 06-01-2017, 06:18 PM
Yes, they are copper plated and I'm curious why. If anyone knows, please share.
My originals polished up well also, but I needed to get new column mounting bolts and Firebird Central had a dirt cheap set that included very nice replacement copper bolts in the package. If anyone needs the old set, let me know.
  #1208
Old 06-02-2017, 08:49 AM
The Boss's Avatar
The Boss The Boss is offline
Ground point for column to chassis?
And go racin' in the street.
  #1209
Old 06-02-2017, 04:41 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Gotta be this.
BJ
  #1210
Old 06-03-2017, 08:32 AM
Well, big disappointment on the NOS tilt levers. While the chrome is better than the repop I bought, the black end looks similar with a more rounded head and matte finish black plastic instead of the original gloss black plastic.
On the copper plated bolts, it doesn't seem that the copper plating we're be necessary just to establish a ground. I can't think of any other grounds on these cars that require a copper connection.
  #1211
Old 06-03-2017, 10:21 AM
Try this...take masking tape, and wrap the chrome to prevent scratching. Then wet sand the plastic with 2500 grit paper to get a consistent satin finish. Using red tube Wenol, hand polish the sanded plastic handle tip until you start seeing a gloss finish. I usually finish it up with the blue tube Wenol to produce the desired finish. I have restored original column shifter handles, turn signal levers, and the partially incorrect tilt levers using this procedure.
  #1212
Old 06-03-2017, 12:37 PM
Formulabruce's Avatar
Horn "clock spring" plunger and or horn plate that spins has copper face on it
" Long may we DRIVE !"
  #1213
Old 06-03-2017, 04:11 PM
njsteve's Avatar
njsteve njsteve is offline
Are they copper plated or actually copper bolts? They could be designed as shear bolts to break and allow the column to move away from the driver in a front end impact.
  #1214
Old 06-03-2017, 10:51 PM
OVERULD's Avatar
That makes sense too, sort of like the decapitation bolts in the cowl that match up with the v-slot in the hood.
BJ
  #1215
Old 06-03-2017, 11:22 PM
unruhjonny's Avatar
i have never observed those bolts to be copper...
1970 Formula 400
  #1216
Old 06-14-2017, 08:00 PM
The bolts are copper Johnny and the reason is as surmised for breakaway purposes.
Moving on... the more I get into restoring the pieces of the Black Car that were originally sent to Tom Fischer as part of the restoration process, the more pis_ed I get. I have spent thousands of dollars having Supercar Creations redo work that should have been done right by Tom. I have also spent hundreds of hours redoing stuff that was in perfect shape when sent to him, and was in crappy shape when I picked up from him after he punted his old career for a new one. The latest example is the dash assembly. It was in concourse shape when sent to him, and this is the shape now. Tom didn't have a spray booth, and apparently didn't want to take the time to put a $5.00 piece of plastic over it while in storage.
Caveat Emptor.
  #1217
Old 06-14-2017, 09:58 PM
OVERULD's Avatar
I'd be angry too, Bob. No excuse for that kind of sloppiness.
BJ
  #1218
Old 06-14-2017, 10:58 PM
Pepi's Avatar
Pepi Pepi is offline
Wow, no kidding. It looks like someone took a scuffing pad to it. Absolutely no reason for stuff like that.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #1219
Old 06-15-2017, 06:00 AM
Judge273's Avatar
I see the opportunity for Bob to make it better than before...
Mike/Illinois
  #1220
Old 06-15-2017, 06:32 AM
njsteve's Avatar
It's the drum roll waiting for the reveal...
Bob, you're such a tease!
BTW, I do know exactly how you feel after my 7-year debacle with the 72 T/A. Hopefully you will be so angry eventually, that you will sell the car back to me. (This has been part of my evil plan all along).
