Old 07-20-2017, 02:09 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
Default 8-lug brake cooling
This 'letter to the editor' was in a 1964 Hot Rod Magazine. Interesting validation of the commendable brake cooling capabilities of Pontiac 8-lug wheels- straight from Kelsey-Hayes who designed and built them.
[Anybody know how to up-size this image?]
Old 07-20-2017, 03:05 PM
Stuart's Avatar
Stuart Stuart is offline
I have that same issue and remember the letter. If I get a chance I'll see if I can find the magazine and scan it.
Old 07-20-2017, 05:15 PM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
I've had a few conversations with a retired engineer from a Tier 1 OE who manufactured many of the famous Muscle Car wheels.
They did a great deal of testing in the 60s, and found the Pontiac 8-Lug and Buick 12" Finned Drum to be the equal or superior to the disc brakes of the era. The key for both is getting airflow over the fins to get a good temperature delta. They work just as advertised. Problem is that Pontiacs and Buicks had a lot of body wrapped around those wheels! I didn't think to ask if the 'scooped' backing plates such as found on drum equipped big tank/big brake Corvettes would be helpful.
Main drawback of the drums was if the drums got wet such as in a deep puddle, etc. they too much longer to become fully effective again than discs.
The other issue with the 8-lug is that drum is highly sensitive to even minor distortions post machining, which cause the annoying pedal flutter. K-H reached out to find a solution - only reliable answer was to cut the drum with the rim and tire bolted into place, which was impractical for production.
As Paul Harvey would say: "Now you know..... the REST of the story!"
Old 07-20-2017, 10:22 PM
U47 U47 is offline
Interesting that then as well as now people still call those wheels aluminum.
Old 07-21-2017, 06:12 PM
Terry M. Hunt Terry M. Hunt is offline
Default 8 lug brake cooling
Rag Top Man, I can appreciate what you are saying about the drums distorting. I think about this every time I have to remove and reinstall a wheel. I take great pains to use a crisscross pattern when tightening the lug nuts and I always use a torque wrench and bring them up to 90 ft lbs in two stages. Of course this is all probably wasted effort when I think of all the times in the past that some tire store gorilla attacked them with an impact wrench. If this happened(likely, I would guess over the decades before I put them on my car) I figure I'm at least not making them any worse.
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 07-23-2017, 06:30 PM
mgarblik mgarblik is offline
I have had good success machining 8 lug drums with the wheels on and torqued on the brake lathe. It's a time consuming ordeal for sure. As they reach their discard diameter, it's more important than ever to have the shoes arched.
Old 07-23-2017, 09:01 PM
U47 U47 is offline
Don't know where your from but arching shoes these days is illegal, and it's been illegal for quite some time. I remember when we had to give up our machine.
Old 07-24-2017, 01:45 AM
Originally Posted by U47 View Post
... arching shoes these days is illegal...
Huh?
Old 07-24-2017, 07:38 AM
real61ss's Avatar
real61ss real61ss is offline
I just had a set arched last week
Tommy's Early Muscle Cars
1959 Pontiac Catalina Sport Coupe 3x2 3 speed manual
1960 Pontiac Ventura 425A / 4 speed
1961 Pontiac Catalina Tri Power / 4 speed
1961 Ford Starliner 390 / 401/ 4 speed
1962 Corvette 327/300 / 4 speed
1962 Gran Prix Tri Power / 4 speed
1963 Pontiac Catalina 421/ 4 speed
1964 Pontiac Catalina 3x2 / 4 speed
Old 07-24-2017, 09:54 AM
ornjcr8 ornjcr8 is offline
Had a set arched last November, did'nt see any Government officials.
Old 07-24-2017, 11:22 AM
Stuart's Avatar
I assume you're referring to re-arcing shoes with asbestos in them.
Old 07-25-2017, 04:43 PM
Ragtop Man's Avatar
Sounds like they are looking at asbestos... the good old linings had it.
But if you had non-organics, I don't see what the issue would be.
