Old 08-02-2017, 01:17 PM
ta man ta man is offline
Originally Posted by 71 Goatman View Post
ta man, I noticed you are running a nice cast aluminum valley pan. Just in the process of freshening my 462 with some KRE heads, after seeing yours am thinking of getting one. Do you run a PVC with that valley pan or did you connect it somewhere else?
I used to run one ,there is a boss on the back you can drill and tap for one.It really needs a baffle for it,or just use a valve cover.I run a vacuum pump currently.
It is a nice part,best thing is you don't have to worry about bending it.I had to trim mine a little more because the heads were milled and shortblock decked.
  #662
Old 08-02-2017, 01:22 PM
Originally Posted by AG View Post
How are you allowed to run sub 11.50 w/o the required safety equipment?
Easy tech on testntune nights.There are usually quite a few newer cars especially the Mopars running in the 10's.I do have a SFI balancer,flexplate,proper lugs on the axles.I've been torn between putting a rollbar in this one or find another roller that is setup.
  #663
Old 08-02-2017, 06:35 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Engine looks great, you are almost there!
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
  #664
Old 08-03-2017, 01:52 PM
71 Goatman's Avatar
71 Goatman 71 Goatman is offline
Thanks take man I am going to pick one up, like the idea of not bending, looks great too!
71 Goatman
Hot Rods & Horsepower.......A diease for which there is no cure.
71 GTO, 463, SD 295 d-port heads, 10.75:1, RPM intake, 502hp/560tq @ the crank, 200r4, 10" Continental convertor, Bullet 234/244 cam, Cliff's Q-Jet, 3:42's w/Eaton True Trac, 5 Power Tours. New performance numbers coming
  #665
Old 08-03-2017, 03:46 PM
71 T/A 71 T/A is offline
If TA Man went to 3.42 gears, he might be able to run 10.50s. Now that's haulin'. He may do it anyways with the 3.08s.
  #666
Old 08-03-2017, 04:02 PM
The last couple years I thought I had to gear up and up the stall to 3800 to 4200 to get into the 10's.
What many don't realize there is a bit of a trick to my setup,my th 350 has a 2.75 low gear set..So if one does the math my th 350 and 3.08 gears has the same effective first gear ratio as a th 400 and a 3.42 gear.
Hopefully all the changes are positive for my milder gear/convertor combo.
More head flow with small port volume
More intake flow with small runners
More compression from 10.1/10.2? to 10.75
More valve lift
Lighter valvetrain,
Near perfect port match,
Lighter rotating assembly ,pistons weigh 420grams,pins 109,(compare to 800grams plus for TRW's and pins)
Zero decked block
Shortblock hard blocked to bottom of water pump
  #667
Old 08-05-2017, 09:30 AM
77 TRASHCAN's Avatar
What octane gas did you use before? Do you think you will to step up octane number now?
Shut it off
Shut it off
  #668
Old 08-05-2017, 11:19 AM
slowbird's Avatar
slowbird slowbird is offline
More valve lift
Lighter valvetrain,
Zero decked block
Did you get new heads? I assumed you sent yours back to be touched up.
  #669
Old 08-05-2017, 11:37 AM
Always ran well on 87....no issues..I plan on running 91 octane in it..Track days add some 94..
  #670
Old 08-05-2017, 11:45 AM
Same heads from 2009.Dave did the 305 CNC port program on them,cut them to 79 cc's,new springs,retainers,keepers,cups valve seals.Dave also did some minor work on the intake opened it up slightly to match the heads..The head/intake mating surfaces were also milled to fit.
  #671
Old 08-05-2017, 01:04 PM
leeklm's Avatar
leeklm leeklm is offline
With the same cam/heads my car runs well with 91 octane , never tried anything less. However, when running less than 93 Octane from the local BP station, I do experience engine run on or diesleing. Base timing is 12 degrees at idle, so not entirely sure what is up with that... 93 takes care of it, so have not pursued any other remedies.
Sent from my XT1585 using Tapatalk
  #672
Old 08-05-2017, 01:32 PM
What is your compression ratio?
  #673
Old 08-05-2017, 01:44 PM
leeklm's Avatar
Doing the math, it comes out to 10.5 if I recall correctly.
  #674
Old 08-10-2017, 02:01 AM
New build is alive,just did a quick fire up..scared the dogs in the house the wife thought it was thunder!Fired up quick!Test drive tomorrow!
Name:	ALMOST DONE!.jpg
  #675
Old 08-10-2017, 07:50 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Good luck!
Go fast, see Elvis!
  #676
Old 08-10-2017, 09:39 AM
rohrt rohrt is offline
More valve lift
Lighter valvetrain,
Zero decked block
Low gear set th350 now it makes sense to me.
who did the port work? I'm always fascinated at how you get more head flow with a small ports. Any tricks you can share?
Good luck on your next outing.
  #677
Old 08-10-2017, 09:52 AM
For interest I'd be interested in the runner volume myself. My notes on another build suggest a set of Dave's 310 cfm KRE heads were about 204 cc's. Maybe not typical but my set of Edelbrock heads ported to 313 cfm at .600" were about 227 cc's.
Old information here:
  #678
Old 08-10-2017, 12:45 PM
Steve,I don't have the exact port volume but I can ask Dave.I believe they are in the 204/205 cc range.This will give you an idea,the intake gasket used is a SCE 128103 which is 1.125 x 2.275.
  #679
Old 08-10-2017, 12:53 PM
All head port work was done by Dave Bisschop at SD Performance using his 305 CNC program.Dave also opened up the intake manifold for a perfect match,as well as milling the heads to raise compression. He also milled the intake side of the head and the intake itself for a perfect fit. Initial plenum and port work of my Torker 2 was performed by Derek Stewart last year.
  #680
Old 08-10-2017, 01:37 PM
Next time you have the intake off double check that gasket port height. Despite what the catalog states I have found the SCE 128103 intake to be about 2.320" tall. I've pointed that out to SCE on at least two occasions. The last time the fellow pulled one off the shelf and measured it while on the phone and agreed.
