I see that there is a kit available to convert the stock choke on '71 Quadrajet to an electric style one. Has anyone ever used this?? Did it work well?? Thanks, Carmine.
I have and it is not only easily installed but works so well.
Kurt L71S....1971 LeMans Sport Coupe 350/TH350 |
![]() Quote:
This is the kit I ordered from Summit Racing. Works like a charm... ![]() https://www.summitracing.com/parts/JET-201355
That kit only works on carbs that had the carb mounted choke, with heat tubes. The '71 carb had an intake mounted "divorced" choke.
Everyday Performance is one source for an electric replacement, for the divorced choke. Links to instruction videos are provided. http://www.everyday-performance.com/electric_choke.htm Last edited by ponyakr; 08-13-2017 at 08:52 AM. |
I bought one from Mountain Man Fuel Systems. No problems. bt
![]() Quote:
"...Just wondering if you ever installed one of these??..."
No. I live in North Louisiana. Our winters are mild. I always removed all the choke stuff, including the top flap. On the race cars, I'd just idle it up, with the idle screw, til the carb got warm, then adjust for warm idle. After doing this for awhile, you can figure out exactly how far to turn the idle screw, on your carb, so that it's a quick, easy process. But, if I was gonna use a choke, I'd definitely go with one of the Everyday Perf models. Looks like they'll work, with any intake. |
![]() Quote:
![]() Quote:
What I don't like about electric chokes - Sometimes during the summer season if I let the car sit for a few weeks or so in my hot un-insulated garage, the gas will dry out of the carb. On an electric choke, having the key/switch turned on & off for a lengthy amount of time (by trying to crank the gas back up out of the tank) it will warm the choke coil up enough to open it too much before the engine is "warm". This will make it more difficult to start "cold". Disconnecting one of the wires from the choke coil helps this until you get gas back in the carb. If I drive it more often it is very reliable though. Some people do think electric chokes are more reliable over the long term. I've been using the original hot-tube coil choke/AFB on my '64 GTO driver for over 17 years. No problems at all. Just some thoughts to consider.
'71 Formula 455 HO Ram Air - Future Project '64 GTO 389 4bbl 4-Spd. - Nice Driver '71 Lemans Sport Conv. Modified-350/350 3.23 Posi - Driver/Project |
Here you go, might be others that are cheaper or call Cliff R.
This is from Carbjunkys on ebay
The More People I Meet, The More I Love My Dogs! |
OK. Thank you, Carmine.
