Old 08-16-2017, 05:46 PM
joes455 joes455 is offline
Default New edelbrock heads
Just ordered a bare set of of their 60609 cnc heart chambered heads with repositioned sparkplug .couldn't get much info on this site's search .Just wondering if heads come with seats ground ?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 08-16-2017, 06:04 PM
thirdgen455's Avatar
thirdgen455 thirdgen455 is offline
Looking at summit it don't look like they are ground.
https://www.summitracing.com/parts/edl-60609
Old 08-16-2017, 07:37 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What are your intentions with them?
Ported? Street / strip? etc etc?
Old 08-16-2017, 09:36 PM
PAUL K's Avatar
PAUL K PAUL K is online now
The seats won't be cut and the guides will need to be honed...a lot!
Go fast, see Elvis!
Old 08-17-2017, 06:16 AM
X2 with Paul.
Old 08-17-2017, 06:45 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Please post up pics when you get them!
Thanks, Kris
Old 08-17-2017, 07:00 AM
Carmine Carmine is offline
I'm assuming that those Edelbrock aluminum heads come with push rod guide plates, would that be correct?? Thanks, Carmine.
Old 08-17-2017, 08:42 AM
Guides,longer valves and valve job no brainer.My original edelbrocks would have needed all of the above ,plus I'll be able to run higher seat height.I was hoping seat's were cut and guides reamed though ,so when they arrived I could put them on my flow bench.
Old 08-17-2017, 09:45 AM
Here is a pic of flow bench fwiw
Old 08-17-2017, 10:49 AM
The valve job applyed will greatly influence flow numbers which should be nice and fat starting at .300" lift.
If these heads will flow more then your last set I really think you need to go with 3.73 gears out back.
Old 08-17-2017, 11:20 AM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
Old 08-17-2017, 11:23 AM
Your Bench looks similar to one of Smokey Yunick's test rigs. I helped Jim Butler and the Boys with a similar set-up (4 cylinder Tempest Block) many years ago.
Give you an "A" on this one. About as close to uniform testing as you are going to get without spending lots of $$$$.
So what are you using for a vacuum source?
ps I built a bench for a 4 cylinder engine that would allow me to read each cylinder at the same time and also compare distribution
of the air to the runners in the manifold, the head, and the cylinders.
This bench was also capable of reading positive (Boost) pressure distribution to each cylinder.
Name:	Joes Bench.jpg
ID:	461393   Click image for larger version
Name:	Cosworth Intake w intercooler on flow stand 1.JPG
Old 08-17-2017, 11:43 AM
Thanks for A rating Tom,vac is being produced by 3 5.5 10 amp vacuums ..they will generate 28 inch up to about 240 cfm .using a Flowquick .I get real close results .Setup lets me take 4 port readings in 10 minutes due to the quick change over from cyl to cyl.There is also an extra vac that is used for entrance porting using the quick disconnect system.Thanks again Tom
Old 08-17-2017, 11:54 AM
28 inch test pressure up to about 240 cfm is fine.
Bob Mullen (426 Hemi Cylinder Head Porter) flowed a lot of stuff at lower test pressures vs 28" and his stuff ALWAYS WORKED.
Old 08-17-2017, 12:55 PM
Nice set up Tom,one other thing that cut alot of time when testing was the modified 1 inch thick radius block that bolted to the port entrance .I did the putty thing for a few ports too many.
Old 08-17-2017, 02:39 PM
I have a similar plexiglas plate (matches stock E-Heads) that has slots so I can position it over the port opening properly. I use button head allen bolts so that the airflow disruption is minimal.
So are you a member of the Flow Bench Forums?
Old 08-17-2017, 03:20 PM
Yes,same here bolt head is almost shallow with radius block .No forum yet sir.
Old 08-17-2017, 04:56 PM
http://www.flowbenchtech.com/forum/
Have to sign up but they are great people and will like to have you join.
Only takes a short time. Tell them that I suggested you join and post up your picture and your vacuum source specs.
Old 08-18-2017, 10:30 PM
AC445 AC445 is offline
Default cnc heads
What size valves will you be using and will they be used on your current engine ?
Old 08-19-2017, 08:42 PM
Don't know yet , I'm would like a 1.9 install height and thinking 2.19 intake and retain the 1.66 exhaust valve.
