Seeems like all the Pontiac timing tapes being sold are for 5-1/4 dia balancer, will it be ok to use on the 6.8 balancer? My balancer is already degreed but some of the markings are off a few degrees according to 2 dialback timing lights.
Do you have the correct timing cover (and scale) for your damper?
How does your balancer check with a straight up non dial back light?
The tape won't work on that balancer.
Try this: Timing Mark Calc If mark on balancer is at TDC, it will work. ![]()
I've never used timing tape. I put TDC at 16 adv at 4 retarded I mark the balancer, that gives me a 20 degree reference mark.
With the 6.8 I just estimate 16 degrees per inch for gross reality check, even tho it is a little closer to 17 degrees (16.85) per inch with more precise math. 16 is a pretty good number for initial timing.
TA Man, that makes an interesting concept for marking the balancer - just use the existing timing tab to mark off new marks with a sharpie. Timing tabs usually have at least 12-16 degrees displayed, and a highly paid engineer already did the math!
"...ridge reamer and ring compressor? Do they have tools like that?" |
Timing cover is 1968 with 0-6-12. Zero on balancer is at tdc. I bought the balancer about 5 yrs ago, a PRP that had every degree painted on. It rusted pretty quickly, so when I had it off last year I derusted and painted it and used a dremel to engrave 'some' of the degree marks. I did 0-10-16-18-20-30-32-34-36-38 and 40. My dist at that time had 34-36 total and 14-16 initial. So I thought those degree marks would be fine. Well now I want to try 30-32 total but still with 14-16 initial. When I set initial at what I thought was 14 it is actually 17 when I turn the knob on the light. After doing a search for timing marks I measured my marks and found out that I have most of the marks off by a few degrees. So rather than confuse myself by trying to add or move the marks I already have I was going to cover them with a tape with nice readable marks and numbers.
![]() Quote:
I recently put a set of KRE heads on my 467 and that is why I want to try around 30-32 total. But the engine likes a lot of initial,at least 14 but 16-18 seems better plus 7 from vac advance. If I turn the dist to get 30-32 total no vac, it has 10-12 initial. It hates 10 and 12 ain't much better.
![]() Quote:
At 10 initial mine is harder to start,and I have to turn the idle screw in so much that I end up with nozzle drip at 950-1000 idle. But I think that might be a very lean idle circuit that I am finally getting straightened out ...I think.
10 is hard to start? Wow. I never would've imagined 10 would cause the starter to complain.
The starter has no problem turning the engine,the engine has to crank many revolutions before it will start with 10. With 14 or more it will start in 1 or 2 revolutions.
That has more to do with your air to fuel ratio with the motor cold then the timing changes!
Normal hot mixtures are in the 14 to 1 range , but a cold motor needs just about the opposite ratio to light off in 1 to 2 revolutions!
If you have the book by Tom Hand about rebuilding Pontiac engines it is in his book about marking the balancers.----BOB
