Correct, usually setting this up on a distributor machine is how it's done, so you would double the number for the engine at the crank.
However, All these recommendations are a very broad range so don't take anything as concrete. Every single engine is going to require it's own timing parameters. As mentioned there are just too many variables that affect the outcome. I am also an advocate of running vacuum advance on any street engine. There is no reason not to. |
Distributor turns HALF SPEED. But I know what you meant. LOL It does get confusing, watching Distributor Degrees and RPM.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
Okay. I knew it had to be a question of terminology. I'm aware how a 4 stroke engine works. I just assumed when we were mentioning timing degrees we were talking about on the timing tape.
There are ways to determine how much timing is being added by the distributor w/o having timing tape. You can do some math and mark the balancer for the total timing number. For example using the diameter of the balancer determine in inches how much equals 36 degrees and make a mark on it with a white or yellow paint marker that distance from the TDC mark. You can then use a timing light and rev the engine until the mechanical curve is all in, then line the 36 degree mark up with "0" on the timing tab.
Vacuum advance units come in many flavors, with different "cut-in" points in inches of vacuum and the travel of the arm varies considerably in how much timing they add. We stock the good VA units here that have light spring tension and short travel. I prefer to use them vs adjustable models and custom tune the travel of the advance by measuring it and adjusting it if/as needed by opening up the slot with a round file, even if I have to use the MIG to reduce travel some. Some folks use the Crane unit where you add the "goofy" cam to the screw to shorten travel. This moves initial timing but works OK if that is what you have to work with.......Cliff
With a dial back timing light just remove springs from distributor weights and set timing were you want it to be.
If the initial gets too low this way push a piece of 1/4" vakuum hose or 1/4" brake pipe on the stop pin at the advance plate and repeat the setting w/o the springs. Next time, with the springs, the initial should come in at 8-12° which is fine. When the timing is done, the carb calibration work starts...... |
Jeff |
http://forums.maxperformanceinc.com/...vacuum+advance And this one: http://forums.maxperformanceinc.com/...&postcount=157 I was trying to pull together all the great advice on here into one thread. Note that I reposted A LOT of Cliff's advice. (although some of it was on cooling too) I DID A LOT of research and bought MANY different vacuum advance cans that each required various amounts of vacuum to start advancing, and the range of advance they provided ranged. I also used the Crane adjustable unit which I found not to be consistent. It is important to understand how each vacuum advance unit works, how much Hg it takes to activate them and how much total advance you'll get. What worked for me was EXACTLY what cliff said to do. The only difference between my setup and what Cliff usually suggests is that for my engine it clearly liked MVA over ported. But as Cliff and the other experts say, to each (engine) his own. If it likes MVA over ported, go with it. SOLUTION: I modified a vacuum advance unit, P/N VC1849/AR19. Stock, it begins advancing at 4-6" of Hg and is all in by 7-10" providing 12* of distributor timing (24* crank timing) (so for my engine I get just about all of the advance at idle). I then had the travel limited by welding in metal so that total travel is .12" which provides 10* of advance at the crank, exactly as Cliff said it would. And it works as promised. Results: Initial timing is 15* and now +10* of vacuum advance added, the cold start-up and cold driving was wonderful. Warmed up driving is all around excellent. I used to have a surge at 3,000 RPM which is now gone as well. I tuned the carb per Cliff's advice (the APT screws). I have not adjusted the tune in nearly two years and it's been terrific ever since switching to the fixed travel, modified vacuum advance unit. If you look closely in this pic, you'll notice some weld marks. Basically, the rectangular hole for the travel used to be much longer. Oh, and for the record, I also cured my temp issues by removing my electric fan and going to a manual 7 blade 18" fan with a modified clutch so that it engages earlier than stock. The car usually runs at the 160* thermostat level, if it's very hot out and I'm on the highway steady for a long time it'll go to about 185*. Wow, I read my old posts and realize the car's come a long way with all these details. Anyway, I hope this helps. Oh, and here's the article many people reference: Quote:
Adam __________________ 1964 LeGTO 469, M21, 3.42 __________________ Sold: 1968 Pontiac LeMans Convertible See it go HERE |
"Trailer-hitching." That's funny, not to mention a very accurate description of what I had going on.
Just a couple of notes on vacuum advance units. When you read thru the list and select one, then attempt to purchase, you will find many of them are either factory order, shown as on the shelf in another store in another State, or NLA. The factory order numbers and those on the shelf in a warehouse or another store someplace may require than you pay the shipping on them.
I've also noticed than many of the ones still available are not USA manufacture, and when tested may deviate some from the posted specifications on them........Cliff
Great thread but having difficulty finding a lot of these VA cans, particularly the ones that activate at lower vacuum hg. Adding this Hinckley piece which also very informative
http://rockridgefarm.com/vettdoc/Timing_101.pdf |
I ordered a bunch. I still have a few left over free to good home, you pay shipping. Not sure which ones I have but can check numbers
Thanks Adam...sending a PM
Using a vacuum advance activated at lower vacuum will in most cases make part throttle ping, and with a faster than factory centrifugal advance itīs guaranteed to ping.
Factory knew this and used a ported source for the vacuum advance with specs suited for the engine. They also added idle bypass air to have the throttle blades in correct position to the off-idle slots due to the lack of vacuum advance at idle speed. With this followed recalibrated idle circuits, better cooling radiators and sensor controlled vacuum advance. At driving speeds, no difference in vacuum advance action, function is the same as with a manifold vacuum source. This works for the RAIV an S.D. engines and will work for any engine wit a hotter than std camshaft. |
I have the B28 can in my points dist. It is tripower so it has to run manifold vac. Engine only makes 8-9'' vac @ idle. The B28 starts at 4'' and is all in at 7'' at idle.
I have one of mine set up almost identical Goatman. It only makes 9 inches at idle up here at 5,000 ft. My vacuum can starts around 4 inches and is all in around 7 inches. I run it on manifold vacuum. I have a quick curve, 36 degrees all in at 2400 rpm. It's 11:1 compression and the car is running fantastic on 91 octane pump gas.
I see Crane offers these units that have adjustable vacuum canisters and limiter plate so you don't have to collect every advance can made. https://www.summitracing.com/search/...rder=Ascending
Carburetor building & modification services Servicing the Pontiac community over 25 years Last edited by shaker455; 09-04-2017 at 10:36 AM. |
#38
Another reason I like the adjustable is that I live at 5,000 feet, and drive to the valley often. Engine makes 3-4 more inches of vacuum near sea level so it gives me the ability to pop the hose off and adjust the sensitivity if need be. |
