#3001
Cool car, sold new at Ted Stevens Pontiac in Los Gatos. I used to work at his Honda dealership right around the corner, and I've already got the plate frame hanging in the garage...
#3003
I'm high bidder...at the moment...we will see.
#3004
Like the no console 4 speed look..
![]() Sent from my iPad using Tapatalk
Mike/Illinois |
#3005
Agreed, I always liked that look too.
#3006
Nope not a harvey victim but a victim nonetheless.
That car is mine it's victim of 30 plus years out in a North Carolina Pasture. Wheels are correct coded mi0 7-28 kn |
#3007
![]() Quote:
I got a chuckle out of seeing the Accel Supercoil bolted to the firewall on a car with a unitized ignition. The guy probably bought that coil, bolted it up, and then went to hook up the main coil wire to the dist cap and discovered there was no place on the top of the distributor to plug it into! Should only take around 100 grand to get it to perfect shape. ;-) |
#3008
![]() Quote:
#3009
I agree. Because the parts are just about nonexistent and very expensive when you can find them, they are very troublesome indeed.
#3010
The auction's over, did you win it?
#3011
Nope, I wasn't going past 20K, that was my bid. If it were lucy blue I would have gone much higher though.
#3012
#3013
Just needs......everything.
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
#3014
Decent car......lots of 70's mods.....
Pretty optimistic on the price, I think.... http://www.ebay.com/itm/182806330452?ul_noapp=true
#3015
That buildsheet and cowl tag are very interesting.
Cool looking TA. ![]()
#3016
John,
What do you see that's interesting?
Mike/Illinois |
#3017
Body number?
#3018
Actually, it looks like a body that was pulled off the line then placed back in a few days later. Referencing the IDENT 180381 from build sheet. New body number is too big (7 digits, not 6).
#3019
Guess not that unusual.
I found at least 3 other 72 Bird build sheets with a body number marked out and another one put in. But they were all on the same 'day'? Box 10 had - 21 01-09 Possibly the person inputting the data was a little off that day? ![]() They had different IDENT numbers, so it may be a 'work ticket' type thing? (at my old work we called them A.I.T.'s for Additional Instructions To) ![]()
#3020
We know that there were a few notable changes to the '72 model year Firebirds that were to take place on and after January 1st. Most if not all were federally mandated safety improvements. It appears Pontiac wanted to (or needed to) come up with a way to identify the previous standards body shells from the bodys which incorporated the updated features. The way this was done was by switching from the old 6 digit Body Number (which was up to at least 177xxx by the end of Dec. '71) to a new 7 digit series which began with '21'.
I have found no 21xxxxx Body Numbers dated before 01A and only a handful of 01A bodys which did carry over the old 17xxxx numbers. Our example here appears to be a body that had been scheduled to be built the last week of December but for whatever reason, was held over in to January. It'd be interesting to know some of the details on this TA to see whether it was assembled with all later changed parts or a mix of early and late. The seat belts/shoulder harnesses are one quick way to ID late from early. Have we ever composed a list if all the changes which were scheduled to take place on or after January 1st? |
