Old 09-27-2017, 06:12 PM
Simple Man's Avatar
ummmm..yeah, I think a little more info would be good................
be a simple...kinda man.
  #5222
Old 09-27-2017, 06:58 PM
72projectbird's Avatar
Look at the scoop on this thing! Jesus!
https://boston.craigslist.org/nwb/ct...290069881.html
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #5223
Old 09-27-2017, 07:10 PM
Nice they converted it to a late model Hemi but that scoop! That's worth at least a $10,000 reduction in price!
Dr. Thomas Sowell
  #5224
Old 09-27-2017, 07:11 PM
goatless's Avatar
goatless goatless is offline
At least it's functional.
1966 GTO
  #5225
Old 09-27-2017, 08:54 PM
GTOnly70's Avatar
GTOnly70 GTOnly70 is offline
Originally Posted by Big Mike View Post
Man, that thing is a cream puff....
The top looks great, though.
  #5226
Old 09-28-2017, 08:26 AM
linden_gto's Avatar
linden_gto linden_gto is offline
while having ZERO function on that engine.
'67 GTO
'97 993 C4S
'86 951
'05 V70R
  #5227
Old 09-28-2017, 11:36 AM
dataway's Avatar
dataway dataway is online now
So Olds engines have like ten valve cover bolts?? Must be nice.
  #5228
Old 09-28-2017, 02:06 PM
george kujanski's Avatar
4 just does not do it. I like cast alum.
George
  #5229
Old 09-28-2017, 02:56 PM
Olds did away with half the bolts sometime around 73. Same gaskets and same valve covers...Just didn't drill all the holes in the covers and head. And seems like it was three bolts on top and two bolts on bottom. Which didn't make any sense to me because the bottom of the cover was longer/wider than the top.
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
  #5230
Old 09-28-2017, 03:39 PM
dataway's Avatar
Totally off topic ... put has any Pontiac owner got so fed up that they drilled and tapped some small holes along the top of the head to add a couple of extra valve cover screws?
  #5231
Old 09-28-2017, 03:40 PM
dataway's Avatar
George
Would be nice is someone produced some cast pieces that looked almost identical to stock. With polished tops they might look the same from a distance.
  #5232
Old 09-28-2017, 03:53 PM
vidguy's Avatar
vidguy vidguy is offline
Default Turkeys?
What's he selling?
Name:	Screen Shot 2017-09-21 at 9.52.09 PM.jpg
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
  #5233
Old 09-29-2017, 03:27 PM
dataway's Avatar
He's not selling his photographic skills that's for sure.
  #5234
Old 10-05-2017, 08:58 PM
I like the bullet holes in the quarter panel!
https://boston.craigslist.org/gbs/ct...263019136.html
1987 Grand National
  #5235
Old 10-05-2017, 10:58 PM
Lightfoot's Avatar
He needs to deduct $3000 for the engine being stripped down to short block.
Says he has the original wheels but he also better have the heads and intake/carb.
I wonder if that was original with red/red vinyl top. Pretty unusual if that's the case.
  #5236
Old 10-05-2017, 11:00 PM
Chris65LeMans's Avatar
“95% there.” ... after you replace 20% of the rusted out sheet metal and replace the at least 15% of stuff under the hood that’s missing.
At least he’s honest about the poor condition of the body - that’s the first time I’ve seen rotten pillars listed as an “ez fix” -type thing.
  #5237
Old 10-05-2017, 11:46 PM
Carefully open the trunk!
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
  #5238
Old 10-06-2017, 10:23 AM
That would be cool but I'm pretty sure vinyl tops were not available in red, at least that year.
Old 10-07-2017, 11:43 AM
http://www.ebay.com/itm/1969-Pontiac...%257Ciid%253A1
Will need rockers, quarters, doors, ect. These parts are easy to come by and for the most part inexpensive.
I love an optimist...
  #5240
Old 10-07-2017, 02:04 PM
dataway's Avatar
If I owned that car I'd sort the mechanicals and drive that baby the way it is. I bet it goes for $8k
