Old 10-10-2017, 09:02 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Default Friday,Friday,Friday
Anybody racing this weekend.
Billy and I will be at Capitol.
Anyone else?
CV1 match race?
[email protected]. 3460#s
Old 10-10-2017, 09:08 PM
slowbird's Avatar
slowbird slowbird is offline
I assume you got your grid replaced? Good luck!!
Old 10-10-2017, 09:15 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Good luck guys!
Go fast, see Elvis!
Old 10-10-2017, 09:19 PM
LiL Jack's Avatar
It was an issue with a set up with a burnout rev limiter that was coming on for .68 seconds while going down the track.
Billy came over and fixed it and there was a carb float issue and they are both squared away so we will see how it runs if it doesn't get rained out.
I will be there Friday only, he will be there Friday and Saturday.
Old 10-11-2017, 12:59 AM
Stan Weiss's Avatar
Jack,
Best of luck. I can see the grid settings causing a problem. But not knowing the grid I don't understand how it would have caused each run to be slower or was that the result of the carb issue?
Stan
Pontiac Pump Gas List
Old 10-11-2017, 07:44 AM
That thing will be bad ass with all the candles lit!! Hell the v6 version was faster than me.
Old 10-11-2017, 10:15 AM
wreckmastr's Avatar
Is it Friday yet?? Old Big Red is gonna come to life this weekend I just hope we can catch it. I can't wait!
ECMTTFMF's
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
Old 10-11-2017, 02:29 PM
Stan Weiss's Avatar
ECMTTFMF's
Billy,
If the changes you made to Jack's grid solves his problem. Then his car should be a bear. But having seen you run 157+ a week ago this past Saturday I believe he will still be chasing you.
Stan
Old 10-11-2017, 05:16 PM
LiL Jack's Avatar
Ain't nobody got that mph for that purple car!
Street type car that is.
Old 10-11-2017, 05:21 PM
LiL Jack's Avatar
LOL, not with your new set up!
LiL Jack's Avatar
Jack,
Stan
Both didn't help any
Old 10-11-2017, 05:26 PM
Dragncar Dragncar is offline
What type of Visners does Sik have ? Are they the Super Chief/High Port kind. If they are, inline. Yours are canted so end the end you should have the MPH in the end.
Let er rip boys.
Old 10-11-2017, 06:36 PM
Stan Weiss's Avatar
Jack / Billy,
I am not sure that the weight that I heard at Capital is correct (3800 lbs). So what does the purple car weigh?
Stan
Old 10-11-2017, 06:56 PM
wreckmastr's Avatar
Jack / Billy,
Stan
3680lbs
6.98 @ 199mph
4.53 @ 164mph
Old 10-11-2017, 06:58 PM
wreckmastr's Avatar
Let er rip boys.
They are Visner Super Chief's that are canted also.
6.98 @ 199mph
4.53 @ 164mph
Old 10-11-2017, 07:54 PM
I'm sure it was a rough road to get that tank to do what it's doing but it's dam sure delivering the pain now. Very impressive
Old 10-11-2017, 08:10 PM
PAUL K's Avatar
X 2
Go fast, see Elvis!
LiL Jack's Avatar
Looks like rain for Friday.
Anyone interested in a track rental at Capitol this fall?
Old 10-11-2017, 08:15 PM
7T2 7T2 is offline
i question the definition of 'canted' vs 'rotated'in this post...
this is a technical discussion which will bore most here, so please indulge me-
definition(s)-
rotated- difference of primary valve angles from intake to exhaust.. for instance- stock pontiac post '67 valve angles are both 14*. 'rotated' term refers to change of that # from 1 valve to the other. as example- if intake primary angle is 14*- like stock late pontiac, and exhaust is 10*, then rotation angle is 4*
canted- refers to the lay over angle which is perpendicular to the primary angle-
the action of valve opening into the bore creates separation from the cyl wall... more lift creates more separation. so canted angle of 5*, like cv-1 creates bore separation @.500" lift that makes 4.35" bore appear as 4.45' bore due to valve lift
when evaluating pics of valve layouts, these definitions will help the viewer to define movements.
"He who laughs last, laughs loudest"
Old 10-11-2017, 08:31 PM
wreckmastr's Avatar
definition(s)-
Perhaps the pictures don't show it well enough, But the lay over angle is far different between the intake and exhaust. BUT no where near as much as Jacks or a BBC. They are goofy weird heads but I'm happy with them so far
6.98 @ 199mph
4.53 @ 164mph
