Old 10-09-2017, 05:13 PM
Dragncar Dragncar is offline
Agree, with the blower on the engine and spinning, basically you would just be dumping more air out of the By-pass Valve at normal cruising speeds and wasting fuel driving the blower to pump ambient air from the blower back to atmosphere under the hood.
A/C Clutch would never have the capacity to hold the power of the engine driving the supercharger. Movies vs reality. Magnetic Particle Clutches were looked at by my company for our Hydrogen Bus program. Durability was poor with the systems and you needed a LARGE magnetic particle clutch on the driven pulley (which was like having a flywheel on the supercharger snout). Been there, done that. (The parts are expensive too).
I was not referring to a actual AC clutch, but just the principle. Much more heavy duty, one made just for a blower. Or some other technology to accomplish the same thing. Eclectically operated but no "clutch" to it. End up being a direct drive, but only when you hit the button. Even if you had to stop the engine while you engaged it, as long as it engaged.
  #42
Old 10-11-2017, 12:00 PM
455'73inElCamino 455'73inElCamino is offline
I am not a racer but am stunned to see that this kind of power can be made with a Pontiac! I was happy just making 530 HP! I gotta get to see some of your Pontiacs run down the track!
  #43
Old 10-11-2017, 01:05 PM
stroker461's Avatar
stroker461 stroker461 is offline
Deep pockets to have that kinda power lol out of my budget lol
  #44
Old 10-11-2017, 03:01 PM
You can imagine the size of the clutch even on a 150 hp ricer vehicle. Not a small diameter thing. Then you stick that on the drive end of a supercharger and all of that mass has to be spun up quickly on any transient response deal.
The VW people did a 1.4 "TSI Supercharger/Turbocharger" set-up for one of their cars some years ago that used a Supercharger for low speed response (then the supercharger was disengaged) and the turbo had enough mass flow from the engine to drive the turbo from that point on for the real HP. Made the power of a 2.3L engine easily and 30% better F.E.
If you really want to see the next wave in Boosting forget the clutch supercharger stuff,
people are playing with electric driven compressors to boost up the engines bottom end performance.
ps That being said, this thread is about 1000 hp @ 7000 rpm engines.
  #45
Old 10-11-2017, 03:38 PM
GTOGEORGE's Avatar
B & M built their Street Chargers to go over 100,000 miles without a problem......so who need a clutch on them?
GTO George
  #46
Old 10-11-2017, 04:48 PM
Thanks Tom, the VW stuff is interesting. Wonder if some sort of coupler could be made that was small diameter and not even electrically operated. One where you would have to stop the engine and turn some bolts/push pins.
George, most of your posts bring threads down. Show what a "non thinker" you really are. Who cares about the useless B&M blower running 100K. The idea I am putting forth is simply one step up from the guys who drive their centrifugal super chargers around without the belt, for economy, or whatever reason the owner chooses.
Then being able to "flick a switch" or manually turn their blower on. Best of both worlds sort of thing.
If one does not think or imagine things that have never been done before this world would be in sad shape.
  #47
Old 10-11-2017, 04:55 PM
GTOGEORGE's Avatar
Don’t need a switch.....B & M did tests and the blower only ate up 1/2 a mile a galllion more!
GTO George
  #48
Old 10-11-2017, 05:05 PM
Thats because its a puny nothing blower of little use to a big Pontiac. I am talking a BIG centrifugal. Roots are thing of the past in many race situations where they used to dominate. Old school, lot of drag. Technology is passing them by.
  #49
Old 10-11-2017, 05:09 PM
GTOGEORGE's Avatar
177 could blower is a pretty good hunk of aluminum!
GTO George
  #50
Old 10-11-2017, 07:29 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
America, the land of opportunity!
[email protected]. 3460#s
  #51
Old 10-11-2017, 08:25 PM
Dragncar, Ever heard of a guy named, Norm Drazy, The PSI Supercharger Brain/Originator? Same guy whose superchargers were banned in Pro Mod as being 'Too Good".
Norm came to see me one time in Dearborn, Michigan. He had this Pro Mod Supercharger strapped on a two wheel cart and ran it up to elevator to my office.
This was years ago when he was banned everywhere. So he figured that if he could sell Ford on purchasing a smaller version vs the Eaton "baby" supercharger he could make some money and help Ford out at the same time.
Dragncar, George's little baby 177 supercharger (believe you called it a "puny nothing blower", sounds about right by the way, is a correct comment. Even George's and Jim's 8-71 superchargers are "nothing" (your words) compared to the stuff Norm was trying to sell to racers at the time. Norm made a video of his PSI blower vs a 14-71 blower years ago. http://www.dragzine.com/news/vintage...-supercharger/
From the article "an alcohol engine running the PSI blower (385ci displacement) made 1,260 horsepower at 28 pounds of boost — the same as a 14-71 blower (552ci displacement) running at 36 psi. The difference was lower manifold air temperature (85 vs. 150 degrees) and less parasitic drag on the engine."
So take anything George posts about superchargers with a grain of salt.
Not sure if Norm Drazy is still out there, heard he walked away for a while and was spending time with his wife. Just be nice to George, He is a Bracket Racer.
Art Whipple has made a nice income selling his version of a screw supercharger to the Brand X Guys for their stangs.
  #52
Old 10-12-2017, 09:52 AM
GTOGEORGE's Avatar
Another TOM useless pat himself on the back post!!
BTW....im making over 1,200 HP with only 11 lbs. of boost with my 8-71.
GTO George
  #53
Old 10-12-2017, 10:19 AM
Stan Weiss's Avatar
GTOGeorge / Tom V,
Instead of the two of you just doing the same old BS two step.
What don't the two of you just ask Billy / wreckmastr. His 3680 lb GTO ran 4.7x @ 157+ MPH in the 1/8 mile the other week at Capital how it is done?
Stan
Pontiac Pump Gas List
  #54
Old 10-12-2017, 10:26 AM
GTOGEORGE's Avatar
I'm doing just fine with my racing and car.....hows your computer doing!
GTO George
  #55
Old 10-12-2017, 10:59 AM
Stan Weiss's Avatar
GTO George
GTOGeorge,
My computer is working perfectly. Wheres as yours and Tom's computers seen to have a malfunctioning keyboard operator.
Stan
  #56
Old 10-12-2017, 11:06 AM
GTOGEORGE's Avatar
GTOGeorge,
Stan
Yea well I'm not a Computer GEEK...........im a Drag Racer!
GTO George
  #57
Old 10-12-2017, 07:53 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Originally Posted by Gary H View Post
Don't know how to post it, and really don't have time to troubleshoot how to do it right now, but my new engine made 1029 hp at 7000 rpm, peak torque was 803 at 6100. 541" with wideport Edelbrocks, Gustram cast intake
Hey Gary,
That's a very impressive pick up. Did the engine make over the 1029HP or was that the peak?
Was that with the Edelbrock carbs?
Calvin Hill
Hill Performance
708-250-7420
  #58
Old 10-31-2017, 05:58 PM
Johannsson's Avatar
Johannsson Johannsson is offline
Late entry here...
My 517 BES engine. This is since 2004
1965 Pontiac GTO 389 Tri Power 4 speed
1965 Pontiac GTO 517 N/A (5.17/135mph 1.17 60f)
1965 Pontiac Tempest N/A 428 (9.81/138mph )
  #59
Old 10-31-2017, 06:06 PM
Dick Boneske's Avatar
How much HP does a similar LS engine put out?
BONESTOCK GOATS
'99 Bonneville SE Sedan
  #60
Old 10-31-2017, 06:26 PM
pastry_chef's Avatar
Some N/A LS power examples.
SAM Racing 2.44 HP / cube - 435 cubes - 1064 horsepower
https://www.youtube.com/watch?v=lndmqwPty0M
BES - 2.4 HP/ cube - 457 cubes - 1100 horsepower
https://www.youtube.com/watch?v=U2aQ291FUY4
