Old 10-26-2017, 04:59 AM
dataway's Avatar
dataway dataway is offline
Default Intake Manifold bolts
Trying if figure out where specific intake manifold bolts go on my 68 GTO with AC.
I've got an OEM set with all standard bolts ... not sure exactly the application.
And I've got a set I took off a donor 68 Lemans, V8, with AC ... the bolts I removed and bagged from the Lemans has three intake bolts with studs. I assume for various accessory mounts.
I think two go on the passenger side front for the funky AC mounting bracket. Anyone know where the other goes?
Did the thermostat housing have a bolt with a stud? Seems like I remember that ... like an alternator bracket or something hooked up to it.
Would the 69 assembly manual be fairly accurate for this kind of thing?
Old 10-26-2017, 05:09 AM
dataway's Avatar
69 assembly manual appears to show a stud in the forward position of the thermostat housing that connects to one side of the "double" upper Alternator mount. (car with PS )
This is the same I remember it for my 68. Am I correct?
Old 10-26-2017, 08:55 PM
MD79TA MD79TA is offline
I have 68 with ac: ps . That is correct on thermostat. I can look at mine for more info if needed . Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 10-26-2017, 09:48 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
That forward thermostat housing bolt/stud combo is + - 1 3/4 OAL . Believe intake combo bolt would be longer.
Leo
Old 10-27-2017, 03:32 AM
dataway's Avatar
The set of bolts I have, appears to be all three bolt/stud combos are the same length. I'll measure them tomorrow.
