Old 11-06-2017, 09:23 PM
HO Kenny's Avatar
HO Kenny HO Kenny is offline
Default 68 Reproduction dash pad info needed
Could someone please supply a pic of the underside of the dash where the bezel sits with the bezel on?
The disassembled Gto I bought came with a A/C reproduction dash pad in the trunk. Either I'm missing something or that dash pad is the worst fitting thing I've ever seen. I can't even get the dash bezel to line up at all. It looks very warped and not shaped like the bezel at all.
Thanks, ken
Old 11-07-2017, 02:59 PM
Verdoro 68's Avatar
The '68 A/C dashpad repros are notoriously bad. I ended up putting a cap over an original.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 11-08-2017, 11:43 AM
HO Kenny's Avatar
That's not good. I don't have the original nor do I have the center vent or the clips on the bottom front.
How does the bezel fit? Is it fit flush with the pad or is it up a bit? I need something to aim for if I'm going to even try to make it fit.
Old 11-08-2017, 05:18 PM
Verdoro 68's Avatar
The repro I had was 10+ years old and lacked the proper mounting posts, etc. I remember having to heavily modify the vent area to get the vent bezels to fit. It fit so poorly Ames refunded my money for it. OPG sells newer repos, but from what I've read they're not much better. I figure if it fit correctly Ames would sell it.
ID:	467214   Click image for larger version
ID:	467215   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 11-08-2017, 06:54 PM
dataway's Avatar
dataway dataway is offline
Wow ... that is bad.
Old 11-09-2017, 04:17 PM
Vol's Avatar
Vol Vol is offline
Thats way off. Great there making repo but only if they are a quality fit.
Old 11-10-2017, 08:46 PM
Verdoro 68's Avatar
Again, that’s the older reproduction. I haven’t seen the newer one. Seems Just Dashes or a dash cap are the best options.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 11-10-2017, 10:01 PM
.....is the repop i got and would like a better pad. Top-surface is the best view.
