Old 11-10-2017, 10:57 AM
4zpeed's Avatar
4zpeed 4zpeed is offline
Default Can I tell you bout my #'s matching engine?
Hey! I have a #'s matching engine!
Wanna see it? Go ahead, click on the pics!
I'm going tell everybody! I'm going tell people I don't even know, who don't even care!
I'm going to discuss it, elaborate on it and talk about it till I'm blue in the face and they're red!
Explain how rare and desirable it is, how I built it myself and on and on... eventually provoking violence leading me to possibly stop.
Obviously I'll just turn to the next poor bast-, er uh, person.
But I just wanted to share it with you guys first cuz I know of your great interest.
Have I told you about my #'s matching engine?
Have you seen my pics? ok ok I'll STO00oooppp!!!
Fine!... I'll tell someone else.......
Edit: I just stumbled across a block that had the same date code as my heads, anyone else ever do that? Now I need a intake dated L197 ....
Frank
ID:	467358   Click image for larger version
ID:	467359   Click image for larger version
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 11-10-2017, 11:16 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
What car does it match.
I don't see an iron intake or chrome covers.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 11-10-2017, 11:20 AM
TedRamAirII TedRamAirII is online now
Matching Intake Manifold? Distributor? Carb? Water pump? Fuel pump?
Bill Nye.
Old 11-10-2017, 11:37 AM
cool allen key spark plugs. This tread needs more pics.
2007 Grand Prix GXP 5.3L
Old 11-10-2017, 11:41 AM
It may be a date matching block and heads, but the main numbers aren't shown?
Old 11-10-2017, 12:06 PM
4zpeed's Avatar
That's all it is, I just happened to notice it.
Can I still say I have a matching #'s engine?
Frank
Old 11-10-2017, 03:17 PM
dataway's Avatar
dataway dataway is offline
Princess Lea to Han Solo "We can reward you with more money than you can imagine"
Han Solo " I don't know .... I can imagine an awful lot"
That has no bearing on the topic, and from my house, your entire engine appears to be matching numbers everything
Old 11-10-2017, 03:24 PM
We would be interested in more info on your (1) matching number engine.
Old 11-10-2017, 03:34 PM
MarkS57's Avatar
MarkS57 MarkS57 is offline
Hey, that looks like a numbers matching engine!
65 Tempest, 400, TH400
86 Fiero SE 2.8
Old 11-10-2017, 04:36 PM
71 T/A 71 T/A is offline
All the numbers do not have to match. LOL.
Example...Block Jan. 15, 1969, Heads, Jan. 22, Distributor, Jan. 8, Water pump, Dec. 15, 68 and so on. As long as the dates are a week or so up to 3 months before your car's build date, you have a numbers matching engine...especially if the last 6 digits of the VIN match the numbers on your block but this is not always the case, 71 455 H.O. is just one example.
Old 11-10-2017, 08:47 PM
Will Will is offline
Not following you 100%. What isn't always the case? 71 455 H.O. is just one example of what?
It's not numbers matching if the partial VIN doesn't match. It can be date correct and/or code correct, but without that VIN it's not numbers matching.
Old 11-10-2017, 09:10 PM
I have a matching numbers engine in my '68.... Partial VIN and EUN match the billing history and dash VIN...However, block was cast 7 MONTHS before the car was built.
Old 11-10-2017, 09:26 PM
dmac dmac is offline
I have a numbers matching engine, a 455 and on the side of the block the 5s match perfectly.
Old 11-10-2017, 09:58 PM
DITTO
There are some years and models, where the numbers on the block do not match the VIN.
Old 11-10-2017, 10:01 PM
4zpeed's Avatar
dataway = "from my house, your entire engine appears to be matching numbers everything"
Thanks data that's what I was counting on.
johnta1 = We would be interested in more info on your (1) matching number engine.
Thanks for pointing that out John.
I was worried, er uh I mean wondering if you wee going to ask.
Ok, well, it's pretty simple,
It's a bit heavy for the size and seems to be the wrong color blue.
It has the spark plug option delete at present, along with the carb, water, fuel, oil pump etc. etc.
These option deletes were not available till I got hold of it, I'll have to work on that.
As for the performance, lets just say it doesn't miss, and hasn't used a drop of gas.
MarkS57 = Hey, that looks like a numbers matching engine!
Thanks Mark, that's awful gracious considering you obviously realize I'm full a chit.
71 T/A = especially if the last 6 digits of the VIN match
Thanks 71 T/A but the vin doesn't match, this is a case of I wish I had a #'s matching engine, thought I'd have some fun since the block and heads are (day) coded.
Heads from the block pictured above are dated L267, intake date is L167.
The L197 heads on the block above were on a 71 400YX in the car when I got it, they are most likely original to the car.
That was about the only original thing left of the driveline.
Makes one appreciate the term #'s matching engine, not that mine is of course.
Or is it...
Frank
Old 11-10-2017, 11:50 PM
pancho400cid's Avatar
pancho400cid pancho400cid is offline
But...
Is it matching numbers???!!!
viva los PONCHOS!
Old 11-11-2017, 05:33 AM
dataway's Avatar
Hehehe... I love engines with the spark plug and carb delete option ... both of those things just cause problems anyway ...who needs them
Old 11-11-2017, 09:23 AM
Bill Hanlon's Avatar
I'll sell you some numbers matching oil for that engine.
Old 11-11-2017, 09:32 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
I think I have a couple of 7" and a couple of 3;s............does that count
