Old 11-29-2017, 08:45 PM
njsteve's Avatar
njsteve njsteve is offline
Any experience with one? What brand was it?
  #442
Old 12-10-2017, 06:42 PM
njsteve's Avatar
I spent some time out in the garage today with the 73. I used it as a the guinea pig for the 75.
I did some measuring on the inside of the air cleaner base and although the outside height is the same as a shaker air cleaner base, the inside height is not the same. The donor base does not have the "drop base" to sit low on the carb so the shaker will sit too high on this base and hit the hood if I try to use it.
So it looks like I will need to find an actual shaker base either a repro 70-72 or a 73 to 79? and add the two mounting tabs I got from Norwood.
Oh well...anybody got a used shaker base from a 73 to 79 sitting around in the attic?
  #443
Old 12-10-2017, 08:10 PM
Judge273's Avatar
Judge273 Judge273 is offline
I am sure Craig can help you with those needs. He's the shaker king bar none.
Mike/Illinois
  #444
Old 12-10-2017, 09:45 PM
cnc's Avatar
cnc cnc is offline
I think Steve this maybe my issue as well....I have not measured mine but it's a tight fit .....I should measure.....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #445
Old 12-10-2017, 10:25 PM
njsteve's Avatar
It’s not a tight fit. It’s a no fit. If I would have tried to fully shut it, it would have broken the sides off the scoop.
  #446
Old 12-11-2017, 09:51 AM
Judge273's Avatar
If you're set on having original 73-79 base. This probably isn't the best asking place.
I have heard the 71-72 repop ones are dead on. Those are also harder to find without a 1 k price tag.
Have you asked Craig? He has a lot of shaker items in his stock. James (Blue 71TA) has a bunch of shaker stuff too.
Wouldn't be surprised you'll need more items as you go along. Functional shakers are a kit of parts for sure!
Sounds like a nice day trip to NH and Ames maybe a good option too...
Mike/Illinois
  #447
Old 12-11-2017, 10:25 AM
njsteve's Avatar
Craig is looking in his stash this week. I have the fully functional 71-72 scoop and wiring. It’s a usable base I need. Year doesn’t matter much since I have Craig’s mounting tabs in hand. I don’t even need good snorkels on the base, since I’ll probably pull the snorkel(s) off anyway. That’s why I’d like to avoid the repro units.
  #448
Old 12-11-2017, 03:45 PM
blue71ta's Avatar
blue71ta blue71ta is offline
I've got a factory, drop-base air cleaner that might work for your intended use. Send me a PM for details.
  #449
Old 12-11-2017, 07:53 PM
njsteve's Avatar
PM sent
  #450
Old 12-12-2017, 12:25 AM
bruwster bruwster is offline
Steve
If you can’t find anything close to you I have a pretty decent one I picked up here a couple weeks ago
It came off a 76 TA
Bruce
Alaska
  #451
Old 12-13-2017, 07:59 PM
njsteve's Avatar
Blue71TA is sending me an old, snorkel-less T/A base. Looks like it should be just what I am looking for. I'd rather play with something like this, than ruin a good piece that someone needs for a correct restoration.
Should arrive just in time to put it under the Christmas tree!
ID:	470028   Click image for larger version
ID:	470029   Click image for larger version
  #452
Old 12-14-2017, 10:49 PM
cnc's Avatar
cnc cnc is offline
njsteve could u take some measuments of this base as I may be in the need as well perhaps.... ......thanks ....Chris
  #453
Old 12-22-2017, 12:59 PM
njsteve's Avatar
Looks like I need to keep looking for another baseplate. Though it was the right one, it is a bit too crusty to use once I de-rusted it. Lotsa little pin holes started peeking through the bottom. No big deal. I'll keep hunting.
  #454
Old 01-22-2018, 02:40 PM
njsteve's Avatar
I found another baseplate, a nice rust free one from another member here. It was from a late 70's T/A. I carefully removed the snorkel and then glassbeaded the entire baseplate. Painted it with satin black epoxy paint. I attached Norwood's shaker lid brackets to the outer rim with a couple screws and JB weld, after carefully measuring and marking with it should go. I also had to move the square breather element hole to clear the passenger side bracket which was in the exact same spot.
Here's how it came out. Now I need to find that pesky 70-75 steel shaker hood.
ID:	473333   Click image for larger version
ID:	473334   Click image for larger version
ID:	473335   Click image for larger version
  #455
Old 01-22-2018, 08:55 PM
Bentwheelbob's Avatar
Screws and JB Weld? Gram’s is going to come back and haunt you....
  #456
Old 01-22-2018, 10:21 PM
njsteve's Avatar
LOL. Actually two small bolts and nuts on each side. A dab of JB Weld was just for added assurance to keep the brackets from shifting. I don’t have access to a resistance welder and the metal is very thin. It actually worked out well for a Frankenstein air cleaner which is what this whole contraption is at this point.
  #457
Old 01-23-2018, 07:29 AM
njsteve's Avatar
And furthermore, Gramma Rose's husband, Simon was the consummate tinkerer. If something around the house broke, he would completely disassemble it and attempt a repair (usually several times) before buying a new one. His workshop was a magical place to behold. Over the years I found several of his signature repairs on the Firebird. So this, in effect, is a tribute to them :-)
  #458
Old 01-24-2018, 08:50 PM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
https://cleveland.craigslist.org/pts...443642666.html
  #459
Old 01-25-2018, 06:19 AM
Love how people so often only lose interest after stripping panels to bare metal before leaving in the weather until they decide to sell.
  #460
Old 01-25-2018, 05:19 PM
njsteve's Avatar
You're right about that. Looking more like i should buy the repro hood. But the shipping is the real deal breaker on those. I wonder if AMES could deliver one to the PY show this year?
