1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
I will check again this week..I have 2 gauges both read different..one shows 13/12 the other 11/10 if I remember correctly.That is at 850rpm/900rpm.
My issue is fuel- living in Kommiefornia, I'm currently limited to 91 octane and Dave advised me to set the SCR to 10.25-10.3:1. I have his 325 cfm CNC e-heads. Eventually I will run a stick, but the get the engine in my car sooner, I'll use a TH-400 and a converter over 2500. So vacuum will obviously be more important.
The rest of the engine is a .020 455, T-II, and a 950 Holley. Geno |
The size of your combustion chambers and anything that then effects the motors compression like deck clearance will have a effect on the vacuum a given motor can pull!
So there are two versions of the OF cam? What's the difference between them?
I'm running the early OF cam (hybrid) with 1.65 solid rollers. Running alum. KRE cnc 290cfm heads, Mighty Demon 850 with Jeff's(Shaker455) version of "idle-ease", 474, 10.25:1 CR.....WITH 4 speed. I was checking tuning just the other day and I cannot remember what the initial timing was set at.....ARRRG, but I can remember that at 900rpm idle the vac. gauge was "searching" between 14-15hg. I thought that was pretty darn good.
Home of WFO Hyperformance Shaker induction. |
Combustion chamber is the Edlround port CNC heart shape at 68.5cc and the deck height is zero to 0.002".
I buy that higher compression yields more vacuum but I don't see why. Most of the vacuum signal is produced by the piston moving down the bore plus the inertia of the air stream after BDC when the piston is inches from the deck so why would a couple of CCs in the chamber make a difference?
Because if you care to look at things for the sake of simplicity as in the decending piston must first suck down whatever size the chamber is before it sucks on the Intake runner.
