#81
#83
Now that's something cool you don't see everyday.
#84
Many of us weekend warriors don't include labor in there repairs or upgrades.
My buddy Corvette Bill would rather spend two hours finding and modifying a bolt when the hardware store, one block away has the correct bolt for 30 cents. Occasionally the Bean counters know what they are talking about. I've changed out many macferson struts over the years. But now, loaded assemblies are available for 10 or 20 bucks more. So do I pay the 20 bucks more or take a chance of getting my head knocked off? --
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk Last edited by Blued and Painted; 01-08-2018 at 01:53 PM. |
#85
Another thought, before I sold my 65 LeMans project (bracket car) with the original 8.2, I ordered a set of aftermarket axles from Jim Mitschke (Monzaz) at jdrace.com, a stud reinforcement girdle and a mini spool (I still have) since the axles were already bolt in.
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
#86
Yeah, but there are photos to back it up.
By the way, that's a FREE junkyard Ford 9" housing you see in that middle photo. Last edited by Chief of the 60's; 01-08-2018 at 03:25 PM. |
#87
I just feel for comfortible doing what I can vs. trusting someone else. In the end, I can get more and better things done with my money. |
#88
Another bit of praise for Quick Performance. Love getting the assembled center section shipped in a nice, shiny, brand-spankin-new, black 5 gallon bucket! lol
4.57 pro gears, 35 spline spool, plug it in and go.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
#89
When I was 60 my arthritis wasn't anywhere near where it is now, that was 5 years ago. See where you are in 5 years from today......
I heard a guy telling that he restored a 73 T/A in his early 60s, then saying that he's glad he did it when he did because after 65 he felt he couldn't have attempted it. My mother is 96, and she says every month there are things she could do 6 months earlier that she can't do any longer. The older you get the more attrition you have, something to consider. The comment about modifying a bolt spending 2 hours on it so you didn't have to buy one is sooooooo true, cause I did that myself, years ago, but yes I did that same thing myself. It all comes down to what you value your time at, if your time has little to no value your likely going to try to build every component on a project. If you value your time you're less likely to do that, even if you have the talents to do it yourself. I wrestle with the time/value question regularly. Yes I can do it, do I really want to though? Presently I like to focus on things that you can't buy to use my fabrication skills on, rather than trying to prove that I can do something I already know I can accomplish. There is no right or wrong answer, the individual has to make the decision and live with their choice. |
#90
[QUOTE=Tom Vaught;5831203]I would personally never run a "c clip eliminator" on any housing. The have a history of leaking. I would spend the money and put it into a proper Ford Rear Axle with big bearing ends (Positive Retention Bearings), Extremely strong axles available, Center sections from the aftermarket allowing quick gear changes, Aftermarket Pigs that are a lot stronger vs a "N" case 9" Pig. Have you checked to see if this (" Housing is actually using 28 spline axles vs the better 31 spline, 33 spline, 35 spline or 40 spline axles? I personally would not touch a 28 spline 9" axle. Did you ask?
Tom V.[/QUOTE I have not found out if it is a 28 spline or not. I saw the guy today but never thought about asking, ( first day back after vacation and it was a busy day ). I will try to find out, but after all the input from the members here I am leaning towards getting an aftermarket assembly. No use in putting junk in it after spending as much as I have already. Thanks guys.
Let's make welfare as hard to get as Veterans benefits! |
#91
Did you happen to notic that "junk" went 4's?
#92
Thanks for all the responses guys. Your making it easy for me to decide on what I am going to do. As far as welding and fabricating , that's what Ive done for 35 years. I have no doubt about doing the fab and welding but I haven't built a rear end before so I would tend to lean towards having it done on a jig. Anyway, after hearing all the costs involved I'm leaning towards buying an aftermarket unit. It sounds like I will have a new, stronger and purpose built rear end made to suit my needs for about the cost of building up a used 9 inch. Thanks for all your input and suggestions.
#93
I have an S60, It was awesome to bolt it in, connect the brake line, bleed the wilwood brakes and drive it. 2-3 hr job with removing my old 12 bolt!!!
#94
These 8.5 10 bolts are unicorns around here. I did my research. Some of y’all have laughed at the questions I have asked but you can’t say I haven’t done my research. I looked at 9 inch 12 bolt and Dana 60 from every source you can imagine and at the end of the day the quick performance 9 inch with explorer discs and a Yukon aluminum thru bolt center will billet everything and a 1350 yoke out the door for 2400 and some change minus shipping just could not be beat. I even got the jack pad the billet fill tube, upgraded to moser axles and got a tru track instead of a clutch posi. Try doing that with a 12 bolt or a DANA. Unless you have the housing to begin with it just didn’t add up to me. I said I’d never run a ford either
#95
When Olds guys sell their cars they like to brag that it has a "factory 12 bolt" like thats a plus! Wrong 12 bolt.
1972 Grand Prix |
#97
I just wanted a bulletproof setup that will last on the street forever. It will never see sticky tires
#98
You do realize those are made for 1000 horse and up race cars don't you? |
#99
I would just build the O-rear that you have; these people seem to have the parts to make it last.
http://www.supercarsunlimited.com/Differential-c10.asp Or sell it to these folks who run with Dr Oldsmobile... https://classicoldsmobile.com/forums...differentials/ |
#100
