An internet friend in France is having a problem with his '56 317. Seems to have an oil leak around the bolt that is used to tighten the filter. There is a copper gasket that has failed. Problems include finding a replacement part and taking apart the filter assembly to replace the gasket. How does one remove the split ring shown in this http://www.pontiacsafari.com/MPC/Pages/page_0095.jpg
picture (1.837 ring) in order to disassemble the assembly. Anyone have any ideas on where to find a copper gasket? Would a plastic oil pan plug do the job?
What about a copper washer for a brake hose? I dont recall the bolt size to hold filter on. But should be able to find something close.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
A brake washer would do the trick if it were large enough. I'd guess the diameter of the bolt is at least a half inch.
Wow- that challenges my memory Bill! However, chances are good that I never disassembled one of them- just cleaned 'em as good as I could and put 'em back on probably. Next time I'm in the barn I'll see if maybe I kept one.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
Fastenal sells copper washers that are typically used for banjo bolts and 1/2" is a size they carry (and larger).
I did find one in the barn, and bolt is still assembled with it. If i ever did take one apart, I don't remember how I got that ring off. Looks like maybe a person could wedge the ends of the ring apart (with a screwdriver?) to release it from its groove? The gasket under the bolt head is indeed a copper washer- looks to be about .040" thick.
You can replace that whole messy can type filter assembly with the later spin on filter assembly. Just use a vertical mount housing from a later full sized Pontiac. You can then use a more common spin on filter. Did this on my 1955 Chieftain and have had no problems in over 20 years.
