Old 01-11-2018, 10:56 PM
Sirrotica's Avatar
FWIW, GM has been using vacuum pumps on most of their diesels as well as some of the smaller displacement gas engines that needed extra vacuum for heater control diaphragms, and vacuum boosters. The 5.7 diesel that came out in 1978 had a vacuum pump in the distributor hole, other applications had belt driven pumps. GM W bodies (GP) had electric vacuum pumps for the brake boosters also. These pumps were made by Saginaw. If you don't want to use a ford part, plenty of GM cars came with vacuum pumps too.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #42
Old 01-25-2018, 01:30 AM
tailored68......... tailored68......... is offline
What the f is hydroboost.....? Sounds like somthing for a big truck...
  #43
Old 01-25-2018, 02:05 AM
ClassicDriverMan's Avatar
ClassicDriverMan ClassicDriverMan is offline
https://www.knowyourparts.com/techni...acuum-booster/
Old Super Chevy article:
http://www.superchevy.com/how-to/brakes/0601sc-hydro/
Tribal Tube Header Rip Off Victim. Ordered March 27, 2012. Told 3-4 weeks. Still waiting
  #44
Old 01-25-2018, 02:47 AM
MD79TA MD79TA is offline
I don't think he really wants to learn based off his previous post. Troll???
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
  #45
Old 01-25-2018, 07:36 AM
Hydraboost is a braking device that allows vehicles with Turbochargers and superchargers to still have great brakes even when under boost conditions.
The systems have been on fast Mustangs as STANDARD EQUIPMENT since 1996. So you are a bit behind in your info and need to do some research into the systems. Hydratech makes a large number of systems for retrofit on older vehicles.
  #46
Old 01-25-2018, 01:52 PM
waterdog waterdog is offline
Default hydro boost
Look into Astro Van hydro boost. Have one on 65 GTO with front disc. Works great and not to hard to install. You need power steering and bend or modify the brake line.
  #47
Old 01-28-2018, 08:14 PM
Default Hydraboost
Now I remember ! The old WW2 GMC trucks used hydraboost !
  #48
Old 01-28-2018, 09:17 PM
Jack P. Jack P. is offline
Originally Posted by Me Notyou View Post
I'd be interested in seeing that. How did you figure out the brackets?
Just saw your post, I will try to get some pictures on Mon. and a bit more info.
  #49
Old 01-29-2018, 03:02 PM
Her is what I did. These pumps come with the air in and out in different locations, I chose this one because it fit my lay out. This is a Ford pump. It was designed for the vacuum brakes on a truck. Some out there look the same but supply much less vacuum. Most of these pumps made for GM only supplied vacuum for HVAC controls and cruise control so keep that in mind. It came with a flat pulley, I changed it to a GM to help keep the belt located.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
http://forums.maxperformanceinc.com/...1&d=1517252469
Name:	belt driven vacuum pump 001.jpg
ID:	473937   Click image for larger version
Name:	belt driven vacuum pump 002.jpg
  #50
Old 01-29-2018, 08:59 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Default Hydro
Mine came off 08 f250. A little more line work and be done.
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
