I have the white and yellow going to the positive on the coil. Is that right?
The yellow goes back down to the starter. There is also a purple with the yellow near the starter. Which terminal do they go onto? One says R And the other S. On the coil I have the negative and the condenser which is also grounded because it is attached to the coil bracket. Is that correct? Sent from my SM-G860P using Tapatalk
http://www.outlawpontiacdragseries.com |
Here is diagram for 68. What year are you working on?
68 400 HO 4sp Convertible Firebird400HO.com My 68 firebird 400 HO convertible Restoration Gallery |
![]() Quote:
![]() I can't remember what color the resistance wire was, but it had a woven insulation. This might help. You have a 67, IIRC. http://thefirstgensite.com/library/e...ir/67wir2.html
"...ridge reamer and ring compressor? Do they have tools like that?" Last edited by Squidward; 02-04-2018 at 07:03 AM. |
Thanks guys. I'm going to have to take you out for a ride and dinner in this thing when it's done.
Anyone have a starter wire tube laying around? Does the positive from the battery go through a tube also our is it just plastic tied to the frame? Sent from my SM-G860P using Tapatalk
Does the positive cable go along the back of the front member then follow the fuel line and go under the motor mount?
![]() ![]() Sent from my SM-G860P using Tapatalk
Hmm... Best I can offer is in this link, figures 12.5 and 12.8.
http://thefirstgensite.com/library/6...ce/FI67S12.pdf I ran mine right along the front side of the crossmember, tied right to the fuel return line. Once it got to the fuel pump side, it runs back under the mount to the starter. It worked well, but not sure if it is factory correct.
"...ridge reamer and ring compressor? Do they have tools like that?" |
It came across the front cross member then right along the oil pan to the starter. There is a metal clips that bolt to the oil pan right under the fuel pump to hold the wire. Then the wire goes above the motor mount to starter.,.
On one website I saw metal clips that pop into the frame like brake line clips. On another site I saw plastic clips. Which is right?
The plastic ones that pop in are for the battery cable along the front of crossmember. It shows in the parts manual in the link above that was provided by squid.
Glad you could get in on it, SilverBullet. I don't play in the resto world because I don't have the patience. But I try to get as close as reasonably possible! My setup is similar to 1967, but a little more 2018 with zip ties!
