Followed closely behind by Magnetti Marelli wiring.
| The Following User Says Thank You to 66sprint For This Useful Post: | ||
The old joke I've heard is that Lucas invented intermittent wipers long before they became industry standard.
Greg Reid Palmetto, Georgia |
GT |
It gets even more comical when you crest the top of the hill with your wipers seemingly frozen in place and let off the gas to coast down the other side as they flap away like a Canadian goose taking off.
Triple Black 1971 GTO |
I had a '58 Caddy with those vacuum wipers.
Even sitting in a neutral position with the wheels pointing forward, a sway bar does increase wheel rate. If you were marginal on tire clearance before, then removed a sway bar all-together, it's certainly possible this could create a tire rub.
What was the reasoning behind removing the sway bar?
| The Following User Says Thank You to JLMounce For This Useful Post: | ||
Threads pulled out of the frame
The threads pulled out of the frame. The car is sitting much lower now. RED FLAGS!!! You need to take a good look at your front suspension. Sounds like the sway bar was in a serious bind.
If the bar has been pulled out of it's frame mount, this suggests that not only was the sway bar bound up pretty good, but it's likely got forces that are pulling it down and possibly pulling or pushing on it as well. The frame mounts are designed to hold the bar in place and let it twist, not to be yanked on. As far as fixing that, a nut cert is typically a good approach, it'll be much stronger than the small bit of threads in the frame itself.
I pulled the threads out of one bolt putting it back on with a 3/8 electric impact. it wasn’t a road mishap. I took it to the alignment shop to get studs welded in the holes like so many suggested. I didn’t have time to have a full diagnosis or alignment today but the shop said upon cursory inspection nothing was amiss.
Yeah, impact is a no-no, as you found out. And yeah, it's possible the sway bar was binding, and it's not now.
Lemme guess, you got 'factory replacement' springs? To 'OE specs'. Or TRWs or something. They are never right. Do you have factory control arms bushings? If so, did you tighten them with the car off the ground? .
Is it possible that you have the wrong size sway bar bushings (too small diameter)? That could explain the binding and pulling bolts out.
| The Following User Says Thank You to JSchmitz For This Useful Post: | ||
I have Hotchkiss springs but it’s never sat this low.
Hotkiss is notorious for providing small block springs. DO you have a part number?
Again, if it has OE type control arms bushings, and you tightened it while in the air, after a while, it can slip off the 'teeth' of the bushings and drop. .
Yes, and good catch on the sway bar bushing call, I didn't mention that when putting possible causes out there. I had an array of sway bar sizes and bushings, and sometimes got them mixed up, so understand how that's possible, personally experienced it.
Maybe the shop bounced the car some after the mount fix and the bushings settled some, or a good dip in the road compressed it some and it didn't return. It might come back up if it's discovered and corrected. .
Still would like to know the part number for the springs, and if OE control arms bushings were used.
I looked, and there are a bunch of Hotchkis spring part numbers, 1" drop, 2" drop, SB, BB, blah blah blah. Between sets and front only, there's more than 9, I stopped surfing at that point. .
The springs came with the car. I don’t know if I ever said but the guy I bought it from was “building” the car to run Pan America. I don’t know why those springs were on it but at the time I ran the part number they were 2 inch lowering. If I have to take them out I will get you the number.
