#81
I'm glad it worked for you. Thanks for sharing those results, Carmine.
#83
I run the same cam on my 463. No vacuum issues even with ac. Idles like a stocker. Running the small booster from an 4 wheel disk TA and 4 wheel disks.
#84
After using a vacuum can for years i decided to install an electric vacuum pump:
https://leedbrakes.com/i-23439165-el...it-series.html Just finished the install today and love this thing. Basically silent operation and my brakes are working better than I ever remember...great pedal and braking!........too cheap for a hydro boost and didn’t trust that a “dual booster” was going to work. Glad I went this route.
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
#85
I wonder about this. Use it and a vacuum switch and relay to turn it on/off. I'll bet you can get one from a salvage yard for $20.00 https://www.summitracing.com/parts/a...xoC_cIQAvD_BwE
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
