Old 03-02-2018, 09:00 AM
Originally Posted by John V. View Post
Is your EUN consistent with the cast date or did the block sit around awhile before becoming part of the engine assembly?
I don't have the EUN handy but I'll post it tonight if I can remember. I know a lot of guys can ballpark build dates by EUN sequence but I'm not one of them. I'd be interested to see what you come up with in regard to that.
Old 03-02-2018, 12:04 PM
Originally Posted by tripower View Post
I’m pretty sure I know how it works. You’re just being an for ass telling the OP he is a “unicorn” for his interest in finding the engine he wants for his car. Whatever a “unicorn”is to you. You can enlighten us.
X2, Last Time I heard, the Owner of the Vehicle gets to decide what information/parts HE wants for HIS project. There always seem to be a lot of people on PY with Opinions about what a Owner can do to His/Her vehicle/project. And with that comes the Cheap Shots along the way. Back to the EUN Info.
Old 03-02-2018, 01:14 PM
unruhjonny's Avatar
other than the cheifs comments, this is a great read!
I'm a numbers guy, not because I place great value in them but because I am fascinated by them
I am ABSOLUTELY with John on this point;
The genesis of my personal interest in this is that my car was purchased with a non-numbers, but correct model year/correct model engine...
1970 Formula 400
Old 03-02-2018, 05:49 PM
Rich-Tripower's Avatar
I have a car built the last week of December 1964 which was delivered to the dealership the first week of January 1965. The block is dated 12/11/64, one head is 11/11/64 one is 12/01/64. The engine was built 12/14/64, things sure moved along quickly. The transmission was built 12/22/64 and the rear end 12/10/64.
Interesting tidbits, it sure was delivered quickly! But more interesting is that the distributor was built 4/27/64. It sure sat on a shelf a long time.
Old 03-03-2018, 11:01 AM
John V. ,
My EUN is 088529
I was wrong about the November date. The block is dated H167. The heads are J077 and J067... So August and October, not Oct and Nov.
Notice heads are one day apart yet a month and a half after the block.
Old 03-03-2018, 03:11 PM
unruhjonny's Avatar
I have read that more often than not, block batches were were done in excess of head batches, so that more often the block casting date precedes the heads...
1970 Formula 400
Old 03-03-2018, 04:57 PM
The other weird thing about my car is that the intake has a '69 date. Not saying it's original but how often would an intake need to be changed for an identical piece?
Old 03-03-2018, 05:10 PM
If the Service People identified a serious Core Shift in the intake (potential intake leak) and they swapped it out for a different one.
We had a couple of cars come thru my uncle's Pontiac Dealership in the early 70 time frame with that issue. Tom V.
We had a LOT more issues with the Overhead Camshaft 6 cylinder bad heads vs that V-8 intake issue.
Old 03-03-2018, 11:27 PM
I always assumed that the intake had been changed but still can't think of a very likely reason to.
Old 03-04-2018, 12:08 AM
John V. John V. is offline
Greg, I have done no research on '68 block dating.
But I can say that EUN 088529 is a pretty early '68 Engine Assembly.
In '64, that EUN was assembled by about mid-October. '64 they produced just more than 600,000 engines during the entire Model Year.
'68 I think totaled more than 800,000 and they may have begun '68 Engine Assembly a bit earlier than in '64 so that I would have expected 088529 to have been assembled even earlier that year.
The H167 would seem reasonable for the block but I think the EUN makes the head cast dates problematic.
Since I have no data to compare to, you would need to check other early EUNs to see if early Oct dated heads make sense for EUN 088529.
For example, if EUN 100000 was installed in a car built before the end of Sept., you would know the Oct heads were impossibly late for EUN 088529.
Have you compared the partial VIN stamp to others from the same Plant in '68? Are you confident the partial VIN is not a restamp?
I can't say one way or the other, to get a better idea you would need to obtain some data and look very closely at the partial VIN stamp.
Old 03-04-2018, 01:43 AM
No John, I have never compared my numbers to others. I'm as certain as possible that the partial VIN isn't a restamp. Mainly because it's a base, auto with A/C GTO and has no special value and was priced as such.
If it was faked, the effort was wasted since the seller did not know that it was a matching numbers (block)...he was a Chevy guy and mistook the EUN for what he thought would have been the partial VIN. He got it from the original owner's mechanic shortly after the death, in his 80s, of that original purchasher. Again, if it was faked, someone along the short line of owners should have used that as a selling point after going through the trouble to re-stamp it.
I'll try to get a good pic of the partial VIN. Looks legit to me. No scratches, etc.
The heads and intake may have come from other cars...who knows? but I feel pretty confident that the block came with the car.
Old 03-04-2018, 02:43 PM
It just occurred to me that it may not be a good idea to post the VIN and also, the fact that in '68 the EUN is listed on the PHS....so...if someone faked the partial VIN stamping, they would also have to fake the EUN stamping to match...correct?
They are both posted on the PHS and stamped on the engine.
So, I'm posting a photo of the EUN stamping..
Old 03-04-2018, 03:04 PM
PurelyGTO68 PurelyGTO68 is offline
It was hit and miss with the EUN in 1968. Some BHCs have it listed.....others are blank and some others just show a bunch of zeros.
My BHC shows the EUN which is 655492. Invoice date of car is 5/27/68. Block cast date would have been C118. 9792506 as cast vs ground and restamped.
Sent from my XT1585 using Tapatalk
Old 03-04-2018, 03:06 PM
johnta1 johnta1 is online now
Greg, I have your eun submission, I would recheck your partial VIN on the block?
The date code and eun are good together.
But the VIN is way off compared to the eun.
If the VIN was 117 instead of 178 it would be good?
(or the block is from a 117xxx car)
The eun would be for a 10B (or something like B/C or D)
EUN Search
Old 03-04-2018, 03:08 PM
Yours is around what Greg's should be.
Old 03-04-2018, 04:45 PM
Greg, since the EUN is on the PHS, that is compelling.
If the block is original to the car, we already knew the VIN would be an anomaly.
John might be able to help figure out if the head dates are reasonable for the EUN using his EUN database. I don't know if he has good data for the Production Dates that builds were getting a particular EUN, but if so, that is the data that will help confirm "good" dates for the heads.
Since John is saying 10B as the earliest Time Built code for your EUN, I'm thinking Oct. 6th and 7th for the heads might be right in line with an engine assembled around Oct 10 and ready for installation in a 10B build so the head dates could be right. Except the engine assembly didn't go into a 10B build and for inexplicable reasons hung around in inventory until winding up in your May build.
A possible explanation, your engine was assembled and ran so poorly on natural gas in the engine plant, that your engine, originally destined for a 10B GTO, never got there and was plucked off the engine assembly line and set aside. Finally somebody fixed whatever was broken and put it back in inventory, whereupon it was placed back on the line and installed in your GTO in May. Whatever the case, it seems to be just an anomaly.
Greg, what about the cast date on the intake? I have seen lots of guys misread cast date tags on blocks, 5s look like 6s and so on. I believe the '68 cast iron intake manifold is the same 9794234 as used in '69? If you have misread the cast date on the intake, could be the intake was the problem that was fixed before it ever went into your GTO and would have a May date? Worth another look.
Old 03-04-2018, 10:39 PM
I just went out in my garage to check what I really already knew and the VIN is good John. It is the same on the VIN plate, the block and the frame rail...checked that when I replaced the trunk pan.
Also, as I said, the EUN and VIN are on my PHS Billing History. Weird, huh?
John V., interesting about the heads being more in line with the EUN than the block.
As for the intake, I just took another look an have to admit that the last digit is not clear...it looks like a 'I269' but could be 'I268'. Still doesn't help it's case for being original to the the car since it's after the car's build date either way.
Old 03-05-2018, 08:55 AM
So, the ancillary equipment like alternator,etc would be a larger spread (newer) from the engine dates?
(instead of 10B dates it would be 05B dates)
  #39
Old 03-05-2018, 11:49 AM
Good example that not every thing is black and white or absolute. Stuff happens.
Our 55 and 61 Bel Air cars each have equipment that would normally receive points deductions at judging but luckily we are able to document those items and prove they are correct for the car. In the end it's just more information to enhance the available knowledge for future generations of enthusiasts.
  #40
Old 03-05-2018, 03:11 PM
John, that could be. Or it could be that the engine was completely dressed out but not yet installed in the car (and partial VIN stamped) when the "defect" was discovered. If the latter, even the accessory items could be early dated. I'm not sure how complete the engine was before it was run on natural gas (I'm assuming they were still doing that in '68). But if not already dressed, perhaps what you suggest is true. Greg would need to tell us what he sees.
And my suggestion is pure speculation. It could be this YS simply got buried in engine inventory and grew old waiting its turn, in which case the dress components would likely show much later dates.. Luckily the PHS shows the EUN otherwise it would be easy to doubt the block.
Anomalies are interesting although often confounding in the absence of documentation. As PurelyGTO68 points out, documentation is a big help as it has in this case.
