Old 03-08-2018, 03:04 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Default How much torque and hp will it make?
466 .020 over 73 455 block, 6X -8 well ported heads (285 cfm int), 2.11/1.77, milled .060", 9.3:1 compression, flat top piston, solid flat tappet 250/260 duration @ .050", 110 lobe sep, 1.65 roller rockers, 4.250" stroke, 6.800" rod, cleaned up Perf RPM intake, 1" plastic open spacer, out of the box 950 HP Ultra carb, 2" pri GTO headers 3.5" flat collectors, 18" extensions.
How much muscle?
Will it have obnoxious idle characteristics at 1000 rpm? Subjective I know, but thought I would get opinions.
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
Old 03-08-2018, 03:16 PM
68azbird 68azbird is offline
680 hp
625 tq
It is easier to fool a man than it is to convince he has been fooled
Old 03-08-2018, 03:30 PM
I ran a single pattern [email protected] 110 lsa 106 icl solid in a 400 and idle was right at about 850-900 rpm.... About 10" vacuum in gear with an 8" convertor. With your longer stroke I'd expect your cam to behave at least as nice.
Power... The dual plane intake is probably going to hold peak power down some... I'm thinking @575 hp 600 ft lbs.
Personally I'd try a T2 or Victor or at least the equivalent of a well ported HSD.
Old 03-08-2018, 05:11 PM
Robert C.'s Avatar
Robert C. Robert C. is offline
570 HP
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 [email protected]
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
Old 03-08-2018, 05:14 PM
scott70's Avatar
scott70 scott70 is offline
I had a similar setup once butt the heads flowed 250's and about 1.5 higher compression than yours. Made like low to mid 500 hp range on the dyno if I remember right. That cam and rockers should make for a noticeable idle....even more so if you added some more compression. I used the T2 intake,,,,liked it very much,,,very responsive for a single plane.
Old 03-08-2018, 05:19 PM
My numbers say 595 HP mostly because of the HP Holley Ultra Carb and the 285 cfm head flow.
Old 03-08-2018, 05:37 PM
charlie66's Avatar
550hp, 572 tq.
My Half AN Injun.....
Old 03-08-2018, 05:39 PM
charlie66's Avatar
Choppy good sounding idle...
Old 03-08-2018, 06:27 PM
joes455 joes455 is offline
520 @ 5900
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 03-08-2018, 06:48 PM
Mike Kasparian,Sr.'s Avatar
Mike Kasparian,Sr. Mike Kasparian,Sr. is offline
Jim , I put together a very similar combo for my son to drive in my car a few years back . Used a bunch of stuff laying around the garage . Used torker 2 with dominator adapter , solid flat tappet cam , shift at 5500 . Ran some 10.70s @123 weighing 3750 . Dusting it off and putting it in the T37 for this year . I figured it had to be 575 at least .
505 CID, 3560 lbs,Tiger heads, NA.
[email protected] mph, 1.29 60', stock suspension
Old 03-08-2018, 06:51 PM
Dragncar Dragncar is offline
Not positive about the HP, but 285cfm out of cavernous 6X-8 D ports. That is not easy, good job my man.
Old 03-08-2018, 07:08 PM
455firebird1969's Avatar
582 HP, will be a beast in a street car.
Old 03-08-2018, 08:38 PM
tom s tom s is offline
585 HP.My 455 with 290 KREs at 10.25 CR,245-252@50 on a 110 600 lift with a factory dual plain and a 750AFB,2in headers made 550.More CI,more cam,bigger carb and better intake has to be worth at lease 35HP.Tom
Old 03-08-2018, 09:35 PM
Judged Judged is offline
603hp 558trq
Old 03-08-2018, 10:36 PM
BADDTA's Avatar
BADDTA BADDTA is offline
Hey Jim
I’ll put in a WAG. With what you know with head porting, it’ll be a torque beast.
627 tq
581 hp
Brian
Boobs & bacon
Old 03-08-2018, 11:07 PM
Outtada box 950 carb may not idle unless there a hellava idle bleed air circuit.
My 9.0:1 will idle on modified Q-JET & 1050 2-circuit carb, but would not even fire with a Stock 68 Q-JET rebuild.
You may want to try a known-capable low-compr low-vacuum carb on break-in.
Once itsa idlng and all, 468 HP.
Old 03-09-2018, 12:11 AM
jm455ho's Avatar
jm455ho jm455ho is offline
580 HP @ 5600
630 TQ @ 4400
www.hobracing.com
Old 03-09-2018, 01:46 PM
BADDTA's Avatar
Originally Posted by jm455ho View Post
580 HP @ 5600
630 TQ @ 4400
Copy cat. Lol
Brian
Boobs & bacon
Old 03-10-2018, 12:40 AM
jm455ho's Avatar
Originally Posted by BADDTA View Post
Copy cat. Lol
Brian
Wow, just realized you had almost the same numbers. I wasn't paying attention, and thought yours were reversed with higher HP and lower TQ.
www.hobracing.com
Old 03-10-2018, 01:48 PM
mjm421's Avatar
mjm421 mjm421 is offline
594 hp
621 tq
This guy knows his way around an engine.
Mike McCarty You can drop the line, but you'll never kill the spirit!
Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far
