Industry Stuff new repro's, updates, other info.
Old 03-27-2018, 09:19 PM
8LUG 8LUG is offline
Hacksawed the battery top off about a 1-1/4" down.(from the top) found out the case sides have stops for the lid but it has silicone and epoxy to seal it. If you cut out the top ,you will cut off the stops that hold the lid.
Old 04-03-2018, 12:54 PM
Default battery
Picture shows how thick the epoxy is holding the battery. bottom of the battery case is 3/8" thick ,the rest is epoxy
Name:	battery bottom.jpg
Old 04-03-2018, 02:44 PM
Cardo's Avatar
Cardo Cardo is offline
Wow. What a POS. Thanks for sharing.... stopped me from buying one!
Old 04-03-2018, 03:05 PM
fred jernejec fred jernejec is offline
I don't even own a topper for my cars John! Fred
Old 05-05-2018, 07:31 PM
Dick Boneske's Avatar
So, what is a good source for batteries for our old Pontiacs. I need the DC12 for my '64. I bought the one in the car from Ames in 2011. It lasted until this spring--will not turn the engine over at all. I guess 7 years is not terrible.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 05-05-2018, 09:20 PM
Cardo's Avatar
I actually talked to Turbo Start on Friday. They could not give me a ETA on when they will have batteries available. National Parts Depot shows them currently in stock though.
Old 05-06-2018, 09:49 AM
Default battery
Hack sawed pieces back together . used a black super glue, now gotta get a 3/8 piece of plastic to put back in the bottom. splice out the positive lead. the get a Odyssey battery to hook up. Then install the top. lotta labor so far
ID:	482384   Click image for larger version
ID:	482385   Click image for larger version
Old 05-11-2018, 07:22 PM
Default BATTERY
Played around fitting a 3/8" PVC bottom in the case and super glued it into place. turned out well. (2nd photo)Old bottom with battery with a lotta epoxy. Ground wire was 3/4 covered with epoxy. Might try velcro on the new battery . on the bottom and the side that next to the case, Dont know how heat will affect it . Turbostart batteries? are they maintainance free or water and acid?
ID:	482774   Click image for larger version
Old 05-11-2018, 07:52 PM
steve v's Avatar
steve v steve v is offline
Great work, I was always curious what these looked like inside.
Are you planning on installing a new battery inside the case or is this gonna be a display only shell now?
Old 05-11-2018, 10:14 PM
Antique Auto Battery was just sold last week, so they are shut down for a while till ownership transfers. Last I heard ,they are a few months behind on orders. I've been waiting since the first of the year. Got a optima battery for now. All battery cases have the indents in them including my 1964 which which should be smooth. If I cancel the order soon I will buy a battery to install inside. Price difference between a new one and my rebuild would be about $150.00 savings. As far as a display You cant seal it up without a battery inside then have to cut it back open again to install the inside battery
Old 05-16-2018, 04:29 PM
New owner is making batteries and the phones are answered.
Old 06-21-2018, 10:43 PM
lilabner's Avatar
lilabner lilabner is offline
Try panel bond to glue it back together. Super strong, and black. Any body shop supply will have it. Porsche 911 air boxes are famous for blowing apart from 1973 to 1983. I fix them with panel bond now. No comebacks in 5 years. never had anything else work.
Old 06-29-2018, 03:12 PM
silverbullet07 silverbullet07 is offline
I called and talked to someone at the phone number and it has been bought by Jim Battery and Manufacturing. They are creating a new website but it is not active yet.
They can still build a r59 battery but it takes 4-6 week lead time. They are taking orders now.
Old 07-12-2018, 01:23 PM
mlewisariz mlewisariz is offline
Do you have the PH# for orders
1970 Trans Am RAIII 4/spd Blue/Blue Van Nuys built
1977 Can AM 400ci Sunroof car
1973 Grand Prix 400 A/T (Parting out)
Old 07-12-2018, 02:27 PM
this was the number I called. 1-800-426-7580
Old 07-12-2018, 05:09 PM
real61ss's Avatar
real61ss real61ss is offline
I have a friend that ordered a battery for his 1962 Chevrolet last spring from Antique Auto Battery, he recieved his battery last Friday
Tommy's Early Muscle Cars
1959 Pontiac Catalina Sport Coupe 3x2 3 speed manual
1960 Pontiac Ventura 425A / 4 speed
1961 Pontiac Catalina Tri Power / 4 speed
1961 Ford Starliner 390 / 401/ 4 speed
1962 Corvette 327/300 / 4 speed
1962 Gran Prix Tri Power / 4 speed
1963 Pontiac Catalina 421/ 4 speed
1964 Pontiac Catalina 3x2 / 4 speed
Old 07-12-2018, 06:37 PM
Last year the old owner got sick. The new owner bought them out this year and is getting the back log of orders made and out.
