Old 04-17-2018, 09:32 AM
ponyakr's Avatar
ponyakr ponyakr is offline
Default Stock Eliminator Info
Due to the recent interest in Randi Lyn's '67 Bird Stocker, I decided to start 2 different threads--one for Stock & one for Super Stock.
The purpose of the threads are to:
(1) Take a closer look at the cars & drivers currently running.
(2) Take a look back at some of the successful cars & drivers of the past.
(3) Discuss possible good combos for a competitive car.
(4) Discuss actual specs & parts needed to build a competitive car, to different performance levels--from a car that will barely run the index, to a national event class winner, to a national record setter.
(5) Provide sources for the info & special parts needed.
(6) Provide a place where those building a Stock/SS car, or considering it, can ask questions.
There are several members here who are racing Stock/SS cars, or have in the past. Some of these guys can share valuable first hand info, most of which can not be found with a simple Google search. Some racers are glad to share info. Some are not. Some are too busy & don't have time. For those who are & will take the time, this will give them the opportunity to share their knowledge with us.
I may never have another Stocker, and most of you won't. But, on this forum, I think there are quite a few who are interested & will enjoy at least some of what this thread will contain.
Looking forward to seeing how much good info is presented in these threads !
Old 04-17-2018, 10:08 AM
Mike Davis's Avatar
This could be a good thread. I posted on your SS thread.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 04-17-2018, 10:23 AM
ponyakr's Avatar
"...Only problem I see is #3&4. No one wants to give out info on these builds.
Hopefully I am wrong and a few will chime in..."
Yeah, it's true that some won't. But, there are some that have & will. The Scott Burton HR mag article revealed a LOT of details I'd never heard.
http://www.hotrod.com/articles/hppp-...tiac-firebird/
Brent Flynn did a long thread, on the Class Racer forum, about switching his '68 Bird from a 455 bracket car to a 400 Stocker. It was a budget build, which included a lot details. He seemed happy to share & answer questions. The car did run quicker than his index.
https://www.facebook.com/brent.flynn.501
This is a good time to add this. For all those interested in Stock/SS racing, I recommend the Class Racer forum.
http://classracer.com/classforum/forumdisplay.php?f=3
I also recommend signing up on the Class Racer Info site. It has LOTS of NHRA Stock/SS specs & info.
http://www.classracerinfo.com/Selection.aspx
Old 04-17-2018, 10:37 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is online now
Classracer is a good sight. Mark Yacavone posts there a lot and he is a long time Pontiac racer.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 04-17-2018, 10:58 AM
ponyakr's Avatar
Yeah, there are quite a few Pontiac racers who post there.
My very first Pontiac hero was Truman Fields, after he won the 1973 US Nats & set a new nat record, in his '68 4-speed Bird.
http://www.risesales.com/pages/Dragr.../t_fields.html
Todd Hoven ran a "Hard Times" tribute car, a while back.
Name:	'73 US Nats Win .jpg
ID:	480831   Click image for larger version
Name:	Hard Times Tribute .jpg
ID:	480832   Click image for larger version
Name:	Todd @ US Nats .jpg
Old 04-17-2018, 12:21 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Didn't Hi Perf Pontiac do a write up on Yacavone and his second gen bird? Pretty sure it was him and he gave up a LOT of info.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 04-17-2018, 12:33 PM
ponyakr's Avatar
Norman Warling has posted some good info on what engines guys are running. He runs a '62 Cat Stocker, and has helped work on his brother's SS cars, one of which held a nat record for a while. He's also neighbors with Scott Burton. Scott & his son race 2 Stockers & one GT car. Those Stockers are 2 of the quickest Pontiac Stockers running today. Both have won lots of big races. Brad has been national Stock champ.
https://www.dragracecentral.com/DRCStory.asp?ID=219127
I would again like to thank Norman for all the info he has posted about the class racers !
Name:	NORMAN WARLING.jpg
Old 04-17-2018, 03:14 PM
ponyakr's Avatar
Default '68 330hp 400 Bird
Thru the years, I suppose I've seen more Pontiac Stockers using this combo than any other. Up until recently, the NHRA hp factor was 330. Then NHRA upped it to 338hp. Not a deal breaker, just required the car to carry more weight for whatever class it runs.
One reason it was a popular combo for many years was that it fit E/SA perfectly. 330hp, 3300lbs = 10 lbs/hp = E/SA
http://www.classracerinfo.com/Engine...9&MAKE=Pontiac
But, since it is now rated at 338hp, and the same engine is rated only 325hp in the '68-'69 GTO, I would say that either GTO is now more competitive than a '68 Bird. But, I don't know of anybody running a '68 or '69 GTO Stocker right now. If anybody knows of any, please post that info.
Adam Strang, who posts here, has his old '68 Stocker for sale, in case anybody is interested. Adam now runs a '68 Bird 4-speed. The 4-speed Birds have a 325hp factor. No, it don't make sense that the same engine would have a higher hp factor if used with an auto. But NHRA adjusts factors based on ET's run at some of the national & divisional races. I think any run which is 1.2 sec or more under the class index, at some races, will get an automatic hp factor increase. That's why many of the quick Stockers sand bag in both qualifying & eliminations.
http://classracer.com/classforum/showthread.php?t=69513
Other drivers of some of the quick '68 Bird Stockers now racing are: Julie Biermann, Chris Stephenson, Bob Aceves, Leo Glasbrenner, Ronald Prince. Todd Hoven also has a '68. He has been driving another brand lately. But Duane Hoven drove the Bird for at least one race. And I think Brent Flynn is gonna try to run his '68 this year. Most '68 Birds run either C/SA, D/SA, or E/SA. They can also run the RA2 round port engine, if they can afford the RA2 heads. Should run a bit quicker, with the heads and bigger cam. And only a 340hp factor.
http://www.classracerinfo.com/Engine...3&MAKE=Pontiac
If these numbers are correct, the same engine has a 365hp factor, in a GTO. This shows why you need to check out all the NHRA specs before choosing an engine/body combo.
http://www.classracerinfo.com/Engine...8&MAKE=Pontiac
If ya'll know of other '68 Bird Stockers, please post that info.
Name:	Julie Biermann.JPG
ID:	480852   Click image for larger version
Name:	Chris Stephenson .jpg
ID:	480853   Click image for larger version
Name:	Bob Aceves .jpg
ID:	480854   Click image for larger version
Name:	Leo Glasbrenner .JPG
ID:	480855   Click image for larger version
Name:	Ronald Prince.jpg
Old 04-17-2018, 10:08 PM
ponyakr's Avatar
Default 455HO
Another engine that has had a lot of Stocker success, thru the years, is the 455HO. Brad Burton has run one for years. Went a little too quick at one race, not too long ago and got a horsepower hit from NHRA. The '72 455HO with RA now has a factor 352hp, in a Bird.
http://www.classracerinfo.com/Engine...0&MAKE=Pontiac
But, the non ram air version appears to have a 330hp factor as of 1/1/18. So, I would assume Brad is now running the non-RA set-up. Maybe Norman Warling will see this & let us know. Anybody else know ?
Scott Underhill held the E/SA national record for a while, with his 455HO T-37.
One of the first 455HO Stockers I can remember reading about was the Tons-a-Fun '72 Wagon. It was built by Gary Wood. His wife Charlene drove it some. They actually had 2 of 'em. One had a reg '72 Lemans front. The other had the GTO type front. There is some info about these cars at the bottom of the page, in this article.
http://www.hotrod.com/articles/0212hpp-pontiac-history/
Not real sure who else is still running a 455HO in Stock. Larry Maxwell was running a '72 Lemans. But this year he has been running a '68 Bird GT car. A '72 recently showed up at a big race. It was listed with a female driver from Canada. Don't know if that's Larry's old car or not. Can anybody name some other 455HO Stockers currently running.
Name:	'71 455HO E-SA Record Holder.jpg
ID:	480895   Click image for larger version
Name:	E-SA Record 7-20-'14.jpg
ID:	480896   Click image for larger version
Name:	Scott Underhill Former E-SA Record Holder.jpg
ID:	480897   Click image for larger version
Name:	Tons a Fun    .jpg
ID:	480898   Click image for larger version
Old 04-17-2018, 10:47 PM
ponyakr's Avatar
Just happened to think, Don Turk sold his GA Stocker & built a T-37. I suppose it has a 455HO.
And, Allen Holingsworth's Formy may also have a 455HO.
Name:	Don Turk T-37 .jpg
ID:	480900   Click image for larger version
Name:	Allen Hollingsworth .jpg
Old 04-18-2018, 07:22 PM
ponyakr's Avatar
Default Older 455HO Cars
I'm sure there have been lots of 455HO Stockers. I have some pics of a few, which I think may be running a 455HO. I could be wrong.
Here are 3 of 'em.
Name:	Black Gold 455HO .jpg
ID:	481001   Click image for larger version
Name:	G. Wood '72 .jpg
ID:	481002   Click image for larger version
Name:	Gary Wood  .jpg
ID:	481003   Click image for larger version
Name:	Super Sleeper 455HO .jpg
ID:	481004   Click image for larger version
Name:	Super Sleeper E-SA .jpg
Old 04-18-2018, 07:51 PM
Monk King's Black Gold ran at the '72 IHRA events in Dallas(track was closer to Denton). I ran my 64 409 Impala in the same classes. I think the car was sold maybe 8-10 years ago and no longer in Texas. Gave the Texas guy my '72 class trophies since the car has historic value winning those classes.
They also had a 64 GTO or Tempest they campaigned. it was for sale at one of the Pontiac Southern Nationals and looked like a big project.
Do not forget to add John Schloe's '69 Firebird campaigned with a RAIV now a D port motor. RAIV was in the 10s way back when.
Old 04-18-2018, 09:00 PM
F/S GTO F/S GTO is offline
The motor that's in the car now still has TRW pistons but someone told me those don't work😉
Old 04-18-2018, 10:19 PM
ponyakr's Avatar
"...They also had a 64 GTO or Tempest they campaigned. it was for sale at one of the Pontiac Southern Nationals and looked like a big project..."
http://www.monkking64gto.com/
"...Do not forget to add John Schloe's '69 Firebird..."
http://www.pontiacpower.com/performance.htm
Name:	'64 Black Gold .jpg
ID:	481025   Click image for larger version
Name:	John Schloe.JPG
Old 04-18-2018, 10:38 PM
ponyakr's Avatar
That's a good point. I assume whatever brand of pistons you run have to meet NHRA weight requirements, and be approved part numbers. So, I can't see how there should be a huge performance advantage.
So, can anybody who has run both the TRW and the high dollar legal pistons give us a report about the performance comparison ?
I assume the Speed Pro/TRW pistons would definitely be plenty good for building a low budget Stocker engine, that would run under it's index.
Old 04-19-2018, 06:26 AM
ponyakr's Avatar
Default '69 T/A Stocker
The '69 T/A is now legal for Stock competition. A '69 T/A clone would make a cool Stocker, IMO.
http://classracer.com/classforum/showthread.php?t=69619
But, with the RA3 engine being rated at 356 hp, I don't think it would be too competitive. Due to the cam rules, I don't think it has any more potential than the 330hp engine, which is rated at 345. Anybody know how much power difference the RA system would make, on a '69 Bird Stocker ? Are the Ram Air cars even required to run the RA system ? Anyhow, like a lot of other combos, it could be built to run just barely under the index. Sometimes, after a combo is run for a while, NHRA can be talked into reducing the hp factor.
http://www.classracerinfo.com/Engine...px?ENGINE=2030
Old 04-19-2018, 06:47 AM
I wasnt just under the index I was 1.04 under the index with TRW pistons with more left.
It's the same shortblock I started out with in the GTO and I struggled to run in the 11's . So that shows you how much everything else matters.
Old 04-19-2018, 07:00 AM
ponyakr's Avatar
Are you allowed to run floating pins, with the TRW pistons ? Any kind of trick rings needed.
Old 04-19-2018, 07:59 AM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
The T-37 Don Turk has now is Larry Maxwells old car. Original 455 HO T-37 I'm told.
I saw where Don said on facebook that they have a new aftermarket block for the car and are getting ready to re-do the engine to make it more competitive.
Old 04-19-2018, 08:20 AM
ponyakr's Avatar
Adam, thanks for that info !
I had no idea that was the same car.
