Old 04-24-2018, 06:29 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
Default fuel tank insulation
Anybody have any pictures of what the original fuel tank insulation pad looks like installed? Or do you car to share what you did with yours? Trying to decide if I want to put the original paper backed type in, of do something else.
Thanks, 68RT
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 04-24-2018, 06:36 PM
Originals are not "paper backed".
Old 04-24-2018, 06:40 PM
68ragtop's Avatar
No kidding? I always thought it was similar to the material used on the floors. That I know was paper backed.
Interesting. Could have sworn I saw a picture of one with paper backed insulation. I'll do some digging
89 Trans am GTA
Old 04-24-2018, 07:27 PM
There were a few designs probably due to different suppliers. The current design has an adhesive. Those are the ones currently on the market. The originals were wider and had nothing on them. I happen to have had 1 for decades and have been trying to find its match but it has not been easy. The last original one I saw was part of a pair that sold for almost $200.00 a few years ago on Ebay.
Old 04-24-2018, 08:07 PM
I probably need to correct myself regarding the width as I have seen wide ones and narrow ones. All of the NOS ones I have had in the past 30+ years were wide. I have also found that the part number was also superseded numerous times. Construction changed over the years as well. Again, probably due to different suppliers.
ID:	481558   Click image for larger version
Old 04-24-2018, 08:44 PM
Scott Thelander's Avatar
Default my 68's
use a material very similar to the floor sound deadner...
my 68 ragtop gto had a large pad ,,, no strip stuff ...
the 70 Lemans just parted had a large pad also....
hmmm ... plant differences ?? mine are 3 out of 4 fremonts
instead of a paper top it seems to have a clear film
and
they were big sheets ....18 x 30 ?
I will get one out for pics from a 68 350 HO 4 speed convert I have in the shop for repairs... gas tank being one of them and dash cluster swap ... and seat
reapir ... and front brakes ... and .....
Scott
Old 04-24-2018, 08:49 PM
I always thought it looked very similar to roofing (tar) paper only a tad brown.
Old 04-24-2018, 08:56 PM
and
Scott
Now that you mentioned it I do recall seeing pads sometimes but not always. I also recall seeing material like the pads only in smaller patches. I cannot recall exactly but something like 1 to 2 inches by 3 to 4 or so inches placed in several spots on the top of the tank.
Old 04-24-2018, 09:01 PM
Default pad
I will be in the shop later tonite as its 82 degrees at 6 pm here in Lacey WA
and I dont want to be in the cave till after dark...
Scott
Old 04-24-2018, 09:14 PM
kk68's Avatar
kk68 kk68 is offline
Here’s a couple pics of my original gas tank and insulation pad when dropped. The insulation had a clear cellophane type material on side that faced the tank and was black tar type material, like the floor insulation. The tank pad looked in good shape when first removed in the photo, but was extremely brittle and easily broke apart every time I handled/moved it.
My 68 was Arlington built.
ID:	481561   Click image for larger version
Don't rush me - it's only year 20 of the 3 year restoration!
68 GTO convertible
YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track,
P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways
C1 224 Triple white
Old 04-24-2018, 11:51 PM
SR-71 SR-71 is offline
I don't know if Patton Glade (P Glad) is still around the list but his are very nice. [email protected]
Old 04-25-2018, 01:41 PM
Exactly. I have two of his and they are just like the original that came off my '68. Black, tar paper like substance with a clear plasting lining bonded to the material. I haven't seen him around here for quite a while but he used to hang out on the Oldsmobile forums as '70Post'..
https://classicoldsmobile.com/forums...tion-item.html
Old 04-25-2018, 03:49 PM
Every 69 I've pulled that had an original pad still in place had one like in post #10,
Old 05-11-2018, 12:13 AM
P Glade P Glade is offline
I'm still here!! Greg, for one, has one or two of my Gas Tank Pads, along with a few hundred other folks with GM A-body cars (and a couple of mid-60's Catalina owners). A great material that duplicates the original look/feel/etc pretty well.
Here's a link to one of my ads (on ClassicOldsmobile.com):
Thanks for the mentions "SR71" and Greg.
Any questions feel free to send me a PM on this site.
Patton Glade
70Post Restorations
Austin, TX
64-72 GM A-Body Gas Tank Pads
http://classicoldsmobile.com/forums/...tion-item.html
Old 05-11-2018, 03:24 PM
Glad to see you're still at it Patton....and I do have two of your pads. If I had another car that needed one, I wouldn't hesitate to get another.
