I’m planning to completely rebuild my ‘70 Tempest’s suspension front and back to OEM spec at the end of the driving season (bushings, shocks, and springs).
Will an internal spring compressor like this from Eastwood be a good choice? ![]() Also, this looks like a good kit for Control Arm bushings. Any feedback on this kit or other recommendations? ![]() Sent from my iPhone using Tapatalk
Kyle Kruszewski
Or would I be better off with an external spring compressor?
Kyle Kruszewski
The internal worked for me....
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
you will not be able to get the external one around the spring while the springs are in the A-Arms
externals are more for struts and their springs I bought the China Freight bushing kit and it works good
some local part stores like auto zone rent them for free. I used the internal as well
72 Luxury Lemans nicely optioned ![]() |
Thanks, guys!
Kyle Kruszewski
The internals have worked for me over the years.. takes a little patience..and be sure it is mounted very well and lubed before tightening! I drop the rod down the shock hole from the top using just bottom clamps and tighten..
