#61
Loved my Continental convertor that I had in my 69 GTO with a stroked 400/462, perfect street/strip.
I could take off slowly like grandma with little to no slip, but mash the gas and all hell would brake loose. My convertor was custom made to my cars specs.
color me gone |
#62
Perfect description!
#63
Is it possible that the pastry chef could be a bigger DOUCHE? Doubtful!
************************************* 1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude |
#64
Continental
I am very pleased with my 13" Continental converter as well.
Driving normal around town and good flash when you hit the go pedal. Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds |
#65
I'm not clear on what your personal experience is in the automotive field...or with Pontiac's specifically? ....Fill me in if you would |
#66
You get what you pay for. Most companies now give 1 free re stall now. Pro torque, UCC, PTC,FTI ....
I just switched to an auto and needed a converter. I was PM'd by a few on this site to spend the money and get a bolt together. Glad I did, I blew the tranny up 3rd time out. Took it apart cleaned it and put it back together. My friend also has a bolt together, if you want it tighter or looser you order a stator to put it. I have another stator for mine too, but I like the tight one on the street. Mine is a PTC and love it so far. |
#67
"Is it possible that the pastry chef could be a bigger DOUCHE? Doubtful!"
Hey, I see you are using one of those POS Continental 10" converters. I'm sure it's fouling your spark plugs that you ran the other thread on. Better get up with the Donut Guy and have him pick a PTC converter for you. Based on his vast experience with torque converters for these Pontiac applications I'm sure you'll quit fouling plugs and you car will run a couple seconds quicker at the track as well!.....LOL....Cliff
#68
Here's a few pics of the 9.5" converters we are currently offering. Have sold quite a few of them and getting excellent reviews on them. Even so, after reading this thread and other various comments from folks who don't even have a Pontiac powered car that moves I'm going to start burying these in the back yard instead......Cliff
If you can read this, thank a teacher. If you can read this in English, thank a Veteran! https://cliffshighperformance.com/ 73 Ventura, SOLD 455, 3740lbs, 11.30's at 120mph, 1977 Pontiac Q-jet, HO intake, HEI, 10" converter, 3.42 gears, DOT's, 7.20's at 96mph and still WAY under the roll bar rule. Best ET to date 7.18 at 97MPH (1/8th mile), Last edited by Cliff R; 09-06-2018 at 10:10 AM. |
#69
You guys are killing me! |
#70
x2
Some real goodies coming in the future months. |
#71
....Your Search engine is gonna throw a rod
#72
No! Do not try! Do! Or do not. There is no try. - Yoda 1967 Firebird Restoration 2005 - 1/25/2017 |
#73
Make a "U" turn and go back to post number three
