Old 10-11-2018, 06:07 AM
1funride 1funride is offline
Formulajones, thank you for taking the time to include the videos. I like the sound of the pypes transverse muffler. It is quiet in the car at cruising, that is nice maybe I can hear the radio again. Your dad's car runs strong, very nice. firebird looks great. Thanks again.
  #42
Old 10-12-2018, 09:44 AM
Lee's Avatar
Lee Lee is offline
FWIW, I had full 3" dual exhaust, Dr. Gas X, large case Xlerator mufflers, and 3" tailpipes on my '67 Firebird. No rattles, no ground clearance issues, no problems at all. The guy who did the install is WAY better than the average muffler shop guy, though.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
  #43
Old 10-12-2018, 12:52 PM
I am struggling a bit on the 2.5" vs 3" exhausts. The Pypes literature indicates the 2.5" transverse muffler system can support 600hp, I find this optimistic but have nothing to base it on as I have no idea what that exhauist and muffler can flow from a CFM aspect. I dont think many/any 2.5" systems would support 600hp.
Is there a CFM rating on the Pypes 2.5" transverse race pro muffler system?
Isnt around 1000 CFM necessary for 500hp?
  #44
Old 10-12-2018, 02:03 PM
I've never seen flow numbers for the Race Pro but they have a nearly identical design to Dynomax Ultraflows. I would be fairly comfortable
HP they support seems to be various claims so not sure what to believe is a limit or where it begins to be a problem. For 99% of street cars I can't even see that being an issue.
What I've seen though is good enough for me. There are Pure Stock racers running into the 12's and even 11 second zone with this system, and F.A.S.T. guys in the 10's. I've gone bottom 13's without trying hard with my own stock 400 in not so great weather conditions (12's corrected). In the future I'll likely build a stroker sleeper engine for this car that should push be in the 600hp range, but the same exhaust system will remain. I'm not worried about it.
  #45
Old 10-12-2018, 03:17 PM
Steve C. Steve C. is offline
Quick and Dirty Exhaust System Math
http://www.exhaustvideos.com/faq/how...pipe-diameter/
Old information here:
  #46
Old 10-12-2018, 03:21 PM
Probably a moot point if Dynomax claims the unrestricted, straight-through design dyno proven to flow up to 2,000 SCFM and support up to 2,000 horsepower. This regarding the UltraFlow welded if one were interested.
  #47
Old 10-12-2018, 04:22 PM
Yep, so many straight through designs that claim big flow I don't know if you can really discern one from the other as far as which would be better. It probably becomes more of a decision of sound quality and which one you like the best.
  #48
Old 10-13-2018, 12:47 PM
2000 CFM through a 2.5" pipe, that is a lot of smoke and mirrors and then a bunch more mirrors. I see Dynomax uses that number generically, too bad. Flow in a pipe is affected by many factors, but the reality of the matter is a pipe of certain diameter will only flow so much before pressure rises. Muffler designs can not change physics. Exhaust scavenging and resonance can help with a muffler design IF the maximum flow rate hasn't already been achieved within the "system". Exhaust system flow out has to equal flow in or pressure will rise, and a 2.5" pipe isn't flowing that much.
  #49
Old 10-13-2018, 05:31 PM
Will Will is offline
I think if you wanted to get the absolute most you could out of system like the Pypes transverse you could run 3" from the headers to an X then to reducers right where the pipes turn to go up over the axles.
Formulajones - thanks for all the links upthread. Particularly liked the vid of your car running at the track.
Does your exhaust have an X in it? I missed that if you mentioned the type of crossover.
  #50
Old 10-13-2018, 05:45 PM
You're welcome Will. Yes it has an X cross over in it.
