Old 09-12-2018, 02:36 PM
JLMounce JLMounce is offline
Default Sniper for Spread Bore manifolds.
Looks like Holley released a Sniper as a direct replacement for QJet owners.
https://www.holley.com/products/fuel.../parts/550-869
They claim it fits standard spread bore manifolds and fits most stock qjet air cleaners.
This may be the ticket for the 2nd gen guys that want to retain their shaker without modifying their intake manifolds or messing with drop base elements.
-Jason
1969 Pontiac Firebird
Old 10-26-2018, 12:20 PM
DogMeister's Avatar
DogMeister DogMeister is offline
Since buying my first '67 GTO in 2003 I have been one of those who said he'd never switch to the dark side and give up his Quadrajet for EFI. This new one from Holley is tempting me. What really got me was the video showing the secondaries waiting until near WOT to open. The plumbing looks kind of screwy - inlets in the back, outlets in the front, but I'm seriously considering it since the one I have at the paint shop right now will end up being a pro-touring resto-mod.
461 Stroker Built by Me -
Old 10-26-2018, 04:42 PM
What are you guys doing that have EEC and a gas tank that vents through a charcoal canister?
Maybe I'm just not seeing it, but it appears these throttle body fuel injection units everyone is so hip on don't appear to have enough vacuum connections to run a system like that properly. Especially when you have a Q-jet with the large 3/8 hose vent on the top. That would be a deal breaker for me.
Old 10-26-2018, 05:13 PM
My Wife's 71 Chevelle had an EEC system on it. That said, nothing was hooked up. The EEC vent lines are all on the car, but no vacuum canister. We went with a standard Tanks Inc system and vented it like a non EEC car. left the lines in tact since they are secure in case we want to ever try to run that.
I can only speak to the FiTech systems as that's what I use, but those have two large 3/8" ports, a 1/16" ported vacuum port and a 1/16" manifold vacuum port.
Since I've never seen one fully equipped, I'm unsure what kind of routing is necessary, but it would seem to me you could tie into the PCV system using one of the 3/8" ports.
-Jason
Old 10-26-2018, 05:29 PM
Interesting. I have 2 cars with functioning EEC that works very well. One is my stock Firebird, the other has a fairly modified 454 in my chevelle that I went out of my way to keep OEM style metering blocks on with the necessary ports to run the EEC, while using an aftermarket main body on a 950 holley.
A customers car I'm doing right now, which is also a Firebird, has EEC. I just modified the Tanks Inc tank to accept the EEC lines, because our plan is to keep the EEC functioning.
I thought possibly in the future I'd try one of these units on one of my cars that will have a Tanks Inc setup, but prefer to keep the EEC functioning. Just curious if they have enough ports to do it. I'm thinking some of them just might.
Old 10-26-2018, 05:54 PM
Any possibility you can send me kind of a schematic on how the EEC in your chevelle is laid out and functions? I'd love to actually get it working in my wife's chevelle. It certainly would cut down on the fuel fumes in the garage.
The Tanks Inc tank has a vent in the tank itself and a vent specific to the fuel pump hat. I believe those can simply by plumbed into the EEC lines to the charcoal canister. My wife's tank has 4 total ports on it. The sender/feed, two 3/8" ports on either side and another in the center of the tank that I believe is fuel return. Does that sound correct?
I'd be interested in guinea pigging this to see if it works.
-Jason
Old 10-26-2018, 06:01 PM
Shoot me a pm with your email and I'll send pictures on how the chevelle is setup, and also how I modified the Tanks Inc tank on the car I'm working on.
I basically soldered in 3 extra nipples in the stock locations on the Tanks Inc tank so the EEC lines on the Firebird would hook right up like factory, then capped the vent that Tanks Inc incorporates into the fuel hat, but it's there to use just in case.
Old 10-26-2018, 06:35 PM
dmac dmac is offline
Just curious- if you have multiple return lines that work by vacuum suction from the tank, won't the tank just 'suck' on the one with the least restriction?
Someone asked a similar question about plumbing the cannister and fuel return lines into a tee. I think that any fuel in the line would prevent any vapors from being returned, and unless a one-way valve is installed, any restriction between the Tee and the tank could cause fuel to flow into the charcoal cannister under pressure, and even the one-way valve might be enough to prevent any vapor from leaving the cannister. If you want to keep the cannister functioning, one of the systems that doesn't need a return to the fuel tank might be one way to go?????
One line for fuel return under pressure to the tank, with another one from the cannister seems okay. Multiple vacuum fed return lines seems like a problem.lines
Old 10-26-2018, 06:46 PM
I think could accomplish that by running the Corvette style system where you have the fuel filter/regulator at the back near the tank, then run the return line off the filter/regulator back to the pump. You plug the vent line attached to the fuel hat, and run the tank specific vent line to the charcoal canister.
I don't know if the Sniper systems can function in that setup, but the FiTech system's can.
-Jason
Old 10-27-2018, 01:24 PM
DogMeister's Avatar
The Sniper spreadbore has 3/8" manifold ports on the front and back, two 3/16" manifold vacuum ports on the front, and one 3/16" ported vacuum on the front.
Old 10-28-2018, 10:25 AM
Interceptor's Avatar
Interceptor Interceptor is offline
Just checked it out. Only supports 500 hp?
70 GTO Restomod -- 400/200-4r, nothing to see here
70 Firebird -- 455/400
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 10-28-2018, 10:53 AM
That should be enough to run the EEC based off what I'm looking at on my cars.
Old 10-28-2018, 10:55 AM
Yeah I saw that. Kind of limits it's uses for some of us. Over 500hp in a well thought out 455 build these days isn't hard to do. But could be well suited for some very mild 400 HP builds and make for a nice driver setup.
Old 10-28-2018, 12:12 PM
grivera's Avatar
grivera grivera is offline
It looks like they turned the throttle body sideways for the spreadbore when compared to the square bore set up.
Will Rivera
Old 10-28-2018, 07:59 PM
64speed's Avatar
64speed 64speed is offline
I am so glad I don’t live in a state with emissions requirements
Old 10-28-2018, 09:41 PM
Neither do I up here in Yavapai County, but I still want my EEC working. That's how the tank vents, and does so in a way that isn't smelly.
Kind of a nice system actually, and is widely misunderstood. It doesn't take HP to run it, is largely hidden from view, and requires no routine maintenance, has no moving parts, and in my experience will last the lifetime of the car.
Yet so many people unhook them thinking they are doing the car a favor only to create a venting issue that causes surging and other weird problems until they realize the tank is no longer vented, lol :shrug:
Old 10-29-2018, 12:02 AM
Yup, no emissions requirements for pre 76 vehicles here in Colorado. I just want the EEC hooked up to keep the car as fresh smelling as possible.
-Jason
Old 10-30-2018, 12:45 PM
DogMeister's Avatar
So I'm getting a little obsessed with this system, to the point of visualizing the feed and return lines in my engine compartment. What do you guys think about this: the manual shows 3/8" ID hose with fittings sliding into the hose for the return line. My '67 sending unit has a 5/16" return port that I'm currently not using. Or is it 1/4"? I'm thinking a 5/16" hard line return would be okay if the sending unit return fitting is 5/16". Changing it to 3/8" would be doable but somewhat of a pain.
Old 10-30-2018, 01:22 PM
This would depend somewhat on the fuel pump you end up using. It would need to be appropriately sized so that a decent volume of fuel it's providing is being consumed, instead of returned to the tank.
If you end up using a larger pump than you need, you can end up in a situation where you need as large, or even a larger return line. Otherwise you build pressure in the return line which causes pressures to creep at the regulator as well.
My experience with FiTech on my 462 leads me to want to be pretty cautionary about the return line. I tried using the factory return line in my original tank with an in-line pump and it never worked. When the engine was cold and needed much more fuel, it was fine, but as soon as temps came up and the engine leaned out, I would start back-building pressure through the return. This caused a rich/lean surge in the system as the additional pressure would increase flow through the injectors. The system would see this rich condition and pull back on duty cycle until I'd get a lean stumble and the system would fire the injectors. This was bad enough the car couldn't even be moved, let alone driven.
If you want these systems to perform reliably, you can't cut corners. 90% of the failures you read about on the FiTech or Holley forums and groups are because somebody tried to cut a corner either for ease of install or to save a buck. I'm going to be extremely blunt here about this. If you don't have the budget or the time/patience to install one of these systems correctly, you're better off not doing it at all.
The carb is much more forgiving than these aftermarket EFI systems.
-Jason
Old 10-30-2018, 01:37 PM
Exactly on point!
Generally, without enough return line, you may not be able to regulate the pressure down far enough, depending on the pump chosen.
Since this system requires 55-65 PSI, and is capable of supporting 500hp currently, I'd personally be looking at a Walbro 255 in tank pump. These pumps put out about 100psi. Regulate that down to 60 psi, and I figure conservatively at 12 volts supplied to the pump, because it's not always going to be 13.5 that some of these pumps use to inflate their numbers, then the pump should support something north of 500hp, close to 600hp, at 60 psi of pressure. That gives a cushion to account for friction and G-force. Any less of a pump and you start to be borderline at not meeting the power potential of the unit.
With that said, I'd most likely want, or need to run a 1/2" feed AND return line. That would be a very solid fuel delivery setup that won't cause any future headaches and if you're only making say 400hp, it gives you a cushion for future upgrades as well without having to go back and reengineer the system.
I find the fuel system upgrades generally cost about as much as the unit itself by the time it's all said and done, to do it in a way that I consider fool proof and trouble free.
