Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 11-17-2018, 01:00 AM
coupeute coupeute is offline
Default Pontiac Engine Cradle
Engine cradle for storage and transportation. Quality made in the USA .
Tig welded and powder coated, grade 5 mounting hardware and heavy
duty 3" diameter casters.
A unique feature is the 45 degree angle of the bottom " skids "
which make it easy to slide the cradle and engine should it be
desirable to transport the engine in the back of a pick up or trailer
without the wheels.
$95 plus shipping. ph. (949) 510 6402
Name:	Pontiac Black Cradle 1.jpg
ID:	498026   Click image for larger version
Name:	Pontiac cradle with Engine.jpg
ID:	498027   Click image for larger version
Name:	Pontiac in pick-up bed.jpg
ID:	498028   Click image for larger version
Name:	Pontiac Metalic blue 1a.jpg
Old 12-01-2018, 11:54 AM
BTTT
Name:	Pontiac Cradle - 4a.jpg
Old 12-01-2018, 01:04 PM
Kennybill Kennybill is offline
California?
Old 12-01-2018, 01:12 PM
HotCat_63's Avatar
HotCat_63 HotCat_63 is offline
Default Hands down the BEST!!!
I have purchased two of these and the quality is hands down the best there is for a Pontiac engine cradle! Here's a picture of my Funny car with its engine mocked up on one of these stands.
Name:	ghost at MCACN.jpg
Old 12-01-2018, 01:28 PM
tom s tom s is offline
James,if someone wanted one for a 265-301 engine could you mod one for it?Tom
Old 12-01-2018, 11:19 PM
Wink 265/301 Pontiac engine cradle
Yes Tom. We have the technology. We can build one.
Old 12-01-2018, 11:20 PM
Originally Posted by Kennybill View Post
California?
Yes, Southern California.
Old 02-04-2019, 04:12 PM
@ Skip Fix …. PM box has space available now.
Old 02-04-2019, 08:06 PM
CatalinaMike CatalinaMike is offline
What part of So. California?
Old 02-04-2019, 08:25 PM
64speed's Avatar
64speed 64speed is offline
How much for shipping to SC 29693
Old 02-04-2019, 10:45 PM
Tom I had a similar question as yesterday I tried to bolt one up to my 78 block that only has the 3 bolt holes per side. Or a bracket to bolt to the cradle and the upper middle bolt.
Old 02-07-2019, 10:38 PM
I think I found and easy solution. The picture of the E head motor above shows the 5 bolt bosses drill. Later motors including 301s use 3 . Here is a picture of the mount and what holes they use. Using a strap that bolts to the cradle where that hole is and tap the strap there to bolt the strap to the cradle and extend the strap to the hole in front of it(3.110") and behind it(3.750") that are near the pan rails so you get more stability than just one hole. If you wanted to pick up that last hole at the very back for a 5 hole block it is 5.150" from the cradle bolt hole.
I have one 557 block with the extra bosses( I think the 78 TA XX block also does) but my 180 HP 78 block only has the 3 needs on the passenger side as shown. and 4 on the other side the 3 used and then the rear most on the driver's side.
I think the 301 just has the 3 mount holes but mine is buried and the POS cradle on it covers them.The POS cradle used for a late motor was some other source 20 years ago and it only picked up one bolt and no brace back by the bell housing bolt holes so the pan is sitting on a board at the back! It was made for early motors.
ID:	504997   Click image for larger version
ID:	504998   Click image for larger version
ID:	504999   Click image for larger version
ID:	505000   Click image for larger version
Old 02-08-2019, 06:07 AM
roy381 roy381 is offline
price and sipping to 08722 please
Old 02-14-2019, 10:28 PM
67GTO4SPEED's Avatar
67GTO4SPEED 67GTO4SPEED is offline
Do you build these? If so, could one be ordered taller? I want to build a run stand and this would save me a lot of time.
'67 GTO 400 HO - Ram Air - 4 speed - 3.55 Safe T Track, A/C, PS, red fender liners
'78 Lemans - Drag car project
Old 02-15-2019, 06:29 AM
Has anyone heard from the OP been waiting in shipped price?
Old 02-15-2019, 07:07 AM
Cardo's Avatar
Cardo Cardo is offline
I heard from him earlier this week. Fedex changed something and he was waiting to hear from them. I am waiting too.
Old 02-15-2019, 08:03 AM
Default Cradle
Thanks much appreciated
Old 02-15-2019, 07:12 PM
Sturdiest and best casters on any cradle I've had. Pontiac one was so good I bought two Chevy ones.
Old 02-16-2019, 08:51 AM
My442 My442 is offline
Do you have a an Olds cradle?
Old 02-19-2019, 04:00 PM
Yes I do have an Olds cradle.
