Is it normal for head gasket to partially block oil galleys on a 1966 326 motor ?
https://drive.google.com/file/d/1wQ7dg7oRNnsuxPxTphlqqlTwCzL13l6F/view?usp=sharing[/IMG]
wanted to share some pictures but I am not qualified to do so evidently.
A '66 326 block shouldn't have oil galleries to the heads. Are you referring to the oil drain backs?
Oil drainbacks are usually always partially covered. Why, IDK. They just are.
yes oil drain backs.
https://drive.google.com/open?id=1rAliSAX5pQOqzSk3QoUkdif-nlbu6Bl7[/IMG] |
yes I mean drain backs.
OK. thank you
