Old 12-31-2018, 09:10 PM
70UglyBird 70UglyBird is offline
Default Removing side bullet mirrors
So I got some new mirrors from Anvil Auto. Just the new glass with Friction assembly. https://anvilauto.com/products/unive...ror-glass.html
I go to take my mirrors off and there is no set screw???? So is there a different style of mirror with no set screw? Or did the guy who painted it decide to "smooth" over it like he did the door handles and rear trunk hinge cover?
Any assistance here is greatly appreciated!!
Thanks!
1973 Firebird, Formula hood, 466 roller cam, ported heads, T56, Hotchkis springs, Koni shocks, DSE Subframe connecters, PTFB upper a arms, re-enforced lowers with global west delrim bushings, C5 brakes front and rear, 18 inch Boss 338 wheels, 4th gen TA power seats seats, Morris seatbelts, hydrotech hydroboost, speed hut gauges
1973 Formula 4spd long term project
Old 12-31-2018, 11:05 PM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Wow that sounds like a cruel hoax that body guy pulled!! Since there is really no way to access the mirrors from the inside of the door panels, you may have to make your best guess and drill thru the filler that is covering the set screw. You can also return those new mirror assemblies at $249 and just buy the actual mirror glass from NAPA. they are $20 each so you will save $200 or so. To replace just the mirror glass while the mirror assembly is on the car: you must use a hammer and gently break the mirror glass and then pull the pieces out from the mirror frame. The glass is just glued in at the factory. Then use silicone glue to install the new mirror glass. You will have to use masking tape to hold the new mirrors in place until the silicone dries. Dave
1970 T/A
Old 12-31-2018, 11:09 PM
I got them for the friction adjustment, mine just flops around and my door panels are custom so no room for joystick. but thank you for telling me stuff sucks lol.
Totally mean that in a good natured way. Totally get what your saying.
Old 12-31-2018, 11:30 PM
Looking at your photo, I'd pull the door trim and make sure they are actually from a Firebird and not a Monte Carlo etc, that mounts using nuts instead of the mounting plate. They are easy to tell simply by looking at them but that small pic doesn't show clearly, but they do appear taller than standard.
Old 01-01-2019, 11:15 AM
JUDGE3 JUDGE3 is offline
yep! purpose of the anvil auto ones is to toss the cable set up! and they are a quality assembly. but yeh, easy to replace just the mirror if one chooses.
Old 01-01-2019, 02:24 PM
NOT A TA NOT A TA is offline
As mentioned above, someone may have swapped G-body mirrors onto your bird (with no set screw or bracket). Pic below shows height difference, yellow is G-body on my Malibu and the other is 2nd gen bird.
John Paige
Lab-14.com
Old 01-01-2019, 05:52 PM
Good pic, John.
Old 01-01-2019, 06:15 PM
That is an awesome pic! Now if that is true I can get them off the doors but not sure if the new mirrors will fit them
Old 01-01-2019, 07:22 PM
72projectbird's Avatar
I was literally just holding up an F body mirror to my GN's mirror. lol
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 01-01-2019, 09:26 PM
I think you guys maybe on to something! Crap I hope this all works out. I had no idea my mirrors weren't stock!
Old 01-02-2019, 09:13 AM
yup
Old 01-02-2019, 11:53 AM
bird72's Avatar
bird72 bird72 is offline
If your bird was Standard base model, I believe in 73 still, Sport Mirrors were an option. Chrome old school drivers was standard and rarely seen. anymore. So maybe the story of your tall adders. I would eventually upgrade to correct if it were mine, but most folk will never notice either.
72 Bird
Old 01-02-2019, 02:23 PM
Excellent point!! I bet that is it. Pretty sure my bird is as base as it got, which is why I dont mind hacking innit as much. I will probably fix down the road but right now just want a drivers mirror flopping around!
Old 01-02-2019, 10:56 PM
cnc's Avatar
cnc cnc is offline
Single drivers side mirror on a base base bird....no pass side mirror....why the hell is it upside down...
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 01-03-2019, 12:37 AM
Thanks Chris, Don't worry about your computer challenges, I just turned my monitor upside down and the car looks as great as ever...Navojo Orange is always bad ass! Mirror is cool! I'm going to try to make my G body mirrors work with my new glass at least for now. I looked up the OER glass part number and it fits firebirds AND Malibu's so there is hope!
Old 01-03-2019, 03:49 AM
Must be because it's a......'mirror image'....
Old 01-03-2019, 01:04 PM
I have the same mirrors on my 71. They mount with two studs like mentioned before, and sit taller on the car. I actually like them more than the stock mirrors. Because they're taller, you can see around and above the quarter panel more than the stockers.
1987 Grand National
Old 01-03-2019, 08:08 PM
One thing to take note of when using other model mirrors on 2nd gen birds is that the plastic mounting plates for each model car are angled to make the stock mirrors for each kind of car sit level and when mixing/matching various mirrors on various models of cars the mirrors can end up looking "funny" because they're not level as well as being taller or shorter than the stock mirrors used on a particular model. If you stand to the rear of the car on the side and look at the mirror it's noticeable when the mirror isn't level. The mirror will look tipped. You can sand the plastic gasket thingies to make the mirrors sit more level. The mirrors on the black car being discussed here look to be tipped in toward the windows but it would be more noticeable if the pics were taken from behind.
John Paige
Lab-14.com
