Old 01-27-2019, 09:36 PM
433lemans's Avatar
433lemans 433lemans is online now
Default Hurst Shifters
I have many HURST shifters, shifter bodies, chrome levers, linkages, linkage parts, knobs, etc., manual and automatic, that I wish to sell. Please let me know what you are looking for and I'll see what I can come up with.
The more specific the request (numbers, description, etc.) the better.
Old 01-28-2019, 02:56 PM
433lemans's Avatar
All who have inquired about shifter parts, please be patient. I will get back to you asap. Thanks.
Old 01-30-2019, 03:06 AM
pont406's Avatar
pont406 pont406 is offline
Im looking for a neutral safety switch for a vintage 70's Hurst Auto Stick
Name:	hurst auto stick 5.jpg
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
Old 01-30-2019, 10:59 AM
433lemans's Avatar
I have a couple of those. Will check it out.
Old 01-30-2019, 12:14 PM
TROYBOYONE's Avatar
TROYBOYONE TROYBOYONE is offline
Default hurst shifters
I'm looking for a early 1965 Gto shifter handle only. It has a rearward angle that is much more than the later almost upright 1965 handle. It is very similar to a 1964 shifter handle.
Gary
Old 01-30-2019, 01:32 PM
433lemans's Avatar
Gary
I have one 64 shifter (no Hurst stamp) and 2 66's, but none for 65.
Old 01-30-2019, 01:35 PM
433lemans's Avatar
pont406
One had this switch mounted but, not knowing what the actual switch is supposed to look like, I assume this was a do-it-yourself installation.
ID:	504273   Click image for larger version
Old 01-30-2019, 01:52 PM
TROYBOYONE's Avatar
Default shifter handle
Price for 1964 shifter handle ?
Old 01-30-2019, 07:03 PM
433lemans's Avatar
1964 GTO shifter. The chrome has been removed from the lever, stamped 2315, revealing stress cracks at the base I'm sure from being heated. The melted plastic receiver bushings confirm this. Otherwise nice needing replating obviously.
The other parts look decent. I will sell with all parts included.
$200 shipped.
ID:	504307   Click image for larger version
ID:	504308   Click image for larger version
Old 09-12-2019, 06:27 PM
2+2=421 2+2=421 is offline
Looking for the reverse knuckle the shift rod goes thru to adjust for. 66 gto..you have one?
Old 09-12-2019, 08:09 PM
433lemans's Avatar
Sorry, no.
Old 09-12-2019, 09:02 PM
Aluminum Chief's Avatar
Aluminum Chief Aluminum Chief is offline
Default Hurst
Looking for #2740 stick.
Thanks KC
Old 09-23-2019, 10:54 PM
433lemans's Avatar
There isn't a #2740 stick
Old 09-23-2019, 11:30 PM
433lemans's Avatar
1964 GTO shifter is sold.
Old 08-30-2022, 02:22 PM
rememberfireball#22's Avatar
rememberfireball#22 rememberfireball#22 is offline
I need complete Competion Plus shifter for 68 GTO. Please let me know. Thanks, Mike
1968 GTO Numbers matching 400 H.O. 4-speed 3:55
1964 T-Bird 46,000 Actual Mile
1928 Model A
2009 Lexus
1981 Dodge D-100
1976 Cadillac Eldorado Convertible
19631/2 Ford Galaxie Fastback
Old 08-30-2022, 11:14 PM
433lemans's Avatar
Just to clarify, are you looking for a factory GTO Hurst or the aftermarket Hurst?
Old 08-31-2022, 07:51 AM
Tim john Tim john is offline
rememberfireball#22, I have a 68 GTO factory HURST shifter available if 433lemans can not help you out. I sent you a PM.
Tim john---
Old 08-31-2022, 09:39 AM
433lemans's Avatar
I don't have what you need ready for sale at this time.
Old 08-31-2022, 01:19 PM
Skippy597's Avatar
Skippy597 Skippy597 is offline
Do you have a shift boot for a super shifter 3?
Old 08-31-2022, 01:38 PM
www.cqm-inc.com
Skippy, Reach out to the above for custom made bellows (shift boots, clutch fork bellows, brake rod bellows, etc..). They have helped me out in the past with high quality pieces, great price points and fast service. Perhaps they can do the same for you.
Tim john---
The Following User Says Thank You to Tim john For This Useful Post:
