#41
![]() I might start a thread on it in the boost/EFI section. I used the FiTech FB user group JLMounce linked, and eventually found the right info. It was a little tricky, but good now. It seems odd that I manufacture the world's most advanced processors, but I'm a little slow from the software side of things! EDIT: Thread created in boost/efi section for those interested! http://forums.maxperformanceinc.com/...26#post6004526
"...ridge reamer and ring compressor? Do they have tools like that?" Last edited by Squidward; 03-20-2019 at 06:37 AM. |
#42
I think you had a lean backfire when you heard the explosion. I know you stated the pressure was ok, but your volume could be low. I would be looking at fuel delivery, make sure you don't have any restrictions in your fuel lines/hoses. I have seen the lack of fuel cause these exact symptoms you are describing.
#43
I'm pretty sure it was all in the ignition. I can for sure say that the adjustable rotor was loose and probably bouncing the spark signal at higher rpms. After finding the #4 plug looser than I would have liked, I checked all of the plugs today. 6 of the remaining 7 were loose. I was using a 6 inch ratchet to tighten them so its not like I had a ton of leverage. They weren't loose in the threads loose but barely snug.
I never would have guessed to check the torque on the spark plugs. Talk about a world of difference. The AFR trims were really having to work for the first couple of miles. MAP readings were way lower. I had a 350 Pontiac in a Lemans with really low miles back in the day. All original with the #48 heads. Talk about a smooth and quiet motor. My 468 is now getting close to that level. Night and day difference. Thanks to all for the help. |
#45
Good news to hear!
