Old 04-02-2019, 09:45 AM
TAQuest TAQuest is offline
Default Too Much Compression ?
I bought a 1967 Firebird 400 convertible out of an estate. The deceased owner had the drivetrain build mostly done. I finished the body and now I'm going to tune the engine for the street. I have a thick notebook of all the parts used.
It has a 1975 400 block.
Edelbrock 60599 Heads 72 cc
Edelbrock Cam
Duration at 0.006" Lift: Intake: 278° Exhaust: 288°
Duration at 0.050" Lift: Intake: 204° Exhaust: 214°
Lift at Cam: Intake: 0.280" Exhaust: 0.295"
Lift at Valve: Intake: 0.420" Exhaust: 0.442"
Timing at 0.050" lift: Open Close
Intake: 3° ATDC 27° ABDC
Exhaust: 42° BBDC 8° BTDC
Centerlines: Lobe Separation - 110° Intake Centerline - 105°
COMP Cams Aluminum Roller Rocker Arms
Rocker Arm Ratio:
1.5
Rocker Arm Style:
Full roller
Stud Size:
7/16 in.
Rocker Arm Material:
Aluminum
Slot Width (in):
0.562 in.
Maximum Spring Diameter (in):
1.500 in.
Rocker Arm Finish:
Red anodized
Edelbrock Performer Intake Manifold
Edelbrock 1411 Carb
Doug's Headers
Super Muncie 4 Speed
3:36 Rear Gears Posi
Funtional Ram Air
I just finished a compression test.
On both #1 and #2, cold and dry, 215 psi.
What can I expect for street performance?
What octane am I going to need to use?
Any suggestions on tuning are greatly appreciated.
Thanks!
Old 04-02-2019, 10:08 AM
pastry_chef's Avatar
Cranking PSI is too high.
I'd swap the cam, intake and carb.
Old 04-02-2019, 10:13 AM
Thanks Chef.
I thought the pressure was high too. Had to get another gage just to make sure.
Is that about 11:1?
Must have been decked?
Why the cam, intake and carb swap?
What would you swap to?
Thanks again for your help.
Old 04-02-2019, 10:29 AM
wbnapier wbnapier is offline
My cold and dry compression is between 185 and 215 on all 8 cylinders.
It is a 1970 455, #48 heads, and a '65 intake. Unknown bore, stroke, and cam, specs with timing at 12 initial and 32 total.
I need to run 91 octane with a 16 oz. bottle of boostane. Even with this, I may have issues on hot days. Without the boostane, the engine diesels when turned off.
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 04-02-2019, 10:32 AM
tom s tom s is offline
My 455 with 48s and dished pistons for 9.5 CR and as I remember pumped 180s run fine on 91 at 36 degrees total.FWIW,Tom
Old 04-02-2019, 10:53 AM
steve25 steve25 is online now
The question comes down to does the block still have the 1975 stock Pistons with the chamfer around its OD, if it does then you will have no isuue with compression being too high as you will be lucky to have 9.2 to 1 .
Old 04-02-2019, 11:05 AM
So the 215 PSI is workable. Thanks.
Old 04-02-2019, 11:08 AM
Thanks Steve.
The test showed 215 psi. Probably not 9:2:1 correct?
The receipts show that they used TRP forged pistons. Everything is new on this build, except the block.
Old 04-02-2019, 11:12 AM
Stan Weiss's Avatar
My guess would be about 10.75:1 CR
Stan
Pontiac Pump Gas List
Old 04-02-2019, 11:15 AM
Stan
Great info. Thanks Stan.
Old 04-02-2019, 11:19 AM
So it's set up like a ram air IV?
Old 04-02-2019, 11:46 AM
STEELCITYFIREBIRD's Avatar
Edit, those are the performer RPM round port ex heads. You should have the 7157 (RA4) cam in it.
Navy Horn 16 Navy Horn 16 is offline
Put premium gas in that thing and send it. I'll bet it hauls ass.
If you want to be on the safe side, go to the airport and get some 100LL and mix a few gallons into your premium.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, [email protected] in the quarter...still tuning.
Old 04-02-2019, 11:56 AM
Let me get this straight here, where talking about a 400 and not a 455?
There are several wild cards here, such as what Pistons, have the 72 cc heads been milled and what is the deck clearance, these all need to be answered.
If you do indeed have 215 psi then even with the Aluminum heads and 91 octane your gonna be close with having detonation or not and may need to step up to a bigger Cam.
Old 04-02-2019, 12:06 PM
Also that performer Intake is strangling those heads!
What is a "Super Muncie 4 Speed"...first gear ratio any how.... what ever it is?
Those birds are pretty light.
Look into the performer RPM top end kit for correct components.
Old 04-02-2019, 12:23 PM
A larger cam will better use the heads and help manage your compression.
I'm partial to solid cams but for a hydraulic flat, maybe a Voodoo 703. Assuming you are around 400 cubes.
As Steve said, the Performer intake is limiting. RPM is much better.
Old 04-02-2019, 12:27 PM
shaker455's Avatar
Edelbrock Cam
Rocker Arm Ratio:
1.5
Rocker Arm Style:
Full roller
Stud Size:
7/16 in.
Aluminum
Slot Width (in):
0.562 in.
1.500 in.
Rocker Arm Finish:
Red anodized
Edelbrock 1411 Carb
Doug's Headers
Funtional Ram Air
Thanks!
No mention of pistons used but I don't think the CR is the culprit .
Most likely the cam is this deal.
cylinder pressure is too great and will detonate.
Suggest a more modern cam like Lunati VooDoo series...703 cam is a good place to start.
Old 04-02-2019, 01:01 PM
How is hood clearance on first gen birds with an RPM?
Old 04-02-2019, 01:56 PM
Stan Weiss's Avatar
While it is old school I would look at an "068" installed on the factory ICL. While I am sure there are better more modern cams, they may need a change in springs or maybe have piston to valve clearance problems.
Stan
