Old 06-07-2019, 10:14 AM
Cardo's Avatar
Cardo Cardo is offline
Default Trunk paint choice
Looking to order some trunk paint soon. Ames trunk paint or The Parts Place? Or are they both the same stuff? Also, anyone know what size tip you need in the gun to shoot this stuff? Ames sells a gun for $45 - should i just buy that one, or is there a Harbor Freight equilivent for half the price?
Old 06-07-2019, 12:54 PM
abefromen's Avatar
abefromen abefromen is offline
http://www.squidsfabshop.com/tr/trunkone.html
Zolatone
Scroll down to the end......I used the same stuff he did and it was 100X better than anything else I ever used in both looks and durability. I used a large tip cheap gun from Harbor Freight.
Old 06-09-2019, 08:24 PM
tjs72lemans tjs72lemans is offline
That looked good. I used the splatter from The Parts Place and tried spraying in my primer gun. It quit spraying almost immediately. I ended up brushing it on with fair results.
Old 06-09-2019, 08:55 PM
400 4spd.'s Avatar
Last year I tried to get some of the black/aqua Zolatone and was told it's been discontinued by the manufacturer.
Check with these people to confirm, but it's not listed.
https://tcpglobal.com/collections/sp...SAAEgKmVPD_BwE
Old 06-09-2019, 11:16 PM
OG68 OG68 is offline
Heard a lot of good things about Guru. Maybe it was here.
Haven't tried it yet but plan to in the next few months.
http://thorntonmusclecars.com/produc...-spatter-paint
Old 06-09-2019, 11:34 PM
400 4spd.'s Avatar
If Thornton's is selling and using it, I would trust it. They helped me out with a very rare W-30 project long ago.
Old 06-10-2019, 09:08 AM
TAKerry TAKerry is offline
Dont know what is correct for your car, but I used an aqua splatter mix in my 77 'bird. Matched the original pretty darn close. I got it from Eastwood, I believe they have a couple of different shades. Also need to put a satin clear coat over the top.
Old 06-10-2019, 10:36 AM
Cardo's Avatar
Thanks for all the replies. Definitely not wanting any of the sprays that need the satin over top. That Guru looks intriguing. I may go that route... plus won't need to figure out what gun i need.
Old 06-10-2019, 12:51 PM
dataway's Avatar
dataway dataway is offline
Let us know how the Guru works out .... I'll be needing trunk paint soon. Same here, not wanting anything that is water based and I can't find the Black/Aqua Zolatone in stock.
Old 06-10-2019, 01:39 PM
I've never liked anything out of the rattle cans because it seems the specs, especially the greens in the black/aqua you're looking for, were very large in the factory splatter, and come out way too small in the rattle cans and don't look correct. Rattle cans just don't have a large enough tip to support the correct size of the specs. On original splatter paint, those green specs are very large and in some cases come out as long slivers if you've ever looked at survivor cars.
I've always used Zolatone with a big tip gun and get very similar to factory appearance results. Been about a year since I've had to use the black/aqua mixture but was available from my local paint supplier at that time. Next time I'm in there I'll check.
Old 06-10-2019, 03:08 PM
Cardo's Avatar
Formula - could you be more specific about the gun? What size tip? HVLP or siphon feed?
Old 06-11-2019, 03:07 AM
dataway's Avatar
Zolatone black/aqua is part number ZT-20-TS02 I see some places listing it, other places saying it is no longer produced.
Old 06-11-2019, 03:47 PM
70GS455 70GS455 is offline
I used that paint once and tried to find it later to no avail. I believe they are now only supplying to vendors such as The Parts Place, etc, changed the part number to PP-20-TS02 and raised the price
Sent from my SM-T817V using Tapatalk
Old 06-11-2019, 04:10 PM
2019-06-11_04-07-27 by Kerry Grubb, on Flickr
Best pic I could get in the situation. This is the aqua from eastwood. It matched really close with the original.
Old 06-11-2019, 04:54 PM
dataway's Avatar
PP-20-TS02 Yep, I'm seeing that part number on Ebay but not on the PP website.
Old 06-11-2019, 09:02 PM
Default color options?
Wasn't the grey splatter used on many years?
Old 06-12-2019, 02:22 PM
I was able to find it
Old 06-12-2019, 03:43 PM
Cardo's Avatar
All right, what kind of gun and tip do you need to spray this with?
Old 06-12-2019, 03:49 PM
dataway's Avatar
Yep, I was using the wrong part number.
Old 06-17-2019, 04:35 PM
2.0 to 2.4 mm tip
