#1061
Mike,I have a QJ,Holley and a pair of AFBs in my cabinet that are dyno carbs and also 2 dist,one with a std gear and one with a poly gear.The last thing I want on a dyno or test stand is a issue!Tom
#1062
The carb that is on there now is the carb it was last on the dyno with. But it's unclear at what the adjustments were on the dyno. Kind of doesn't matter, simple carb adjustments shouldn't cause the 'noise' issue, but it is one factor that will eventually be addressed.
I was informed the carb, due to elevation concerns, was jetted up 2 steps prior to shipping. Not a deal breaker, also wouldn't cause any 'noise', and that will have to be revisited once running properly and road tests can be accomplished. Yes, the objective is to resolve the rough running issue with the next effort, then the 'noise'. My comments of 'theorizing' is a reach as well as some wishful thinking thrown in for good measure. Also to point out a potential cause that can easily be eliminated. (Following the process of elimination approach). .
#1063
You got good help on the way, I have a feeling this will finally be diagnosed soon.
One question: Is the same oil pump and driveshaft in the engine that experienced the oil starvation/pickup tube fall off? If not, at what point was it replaced? |
#1064
I think if I had the same problem (the noise), and couldn't identify it by listening I would.
1. Turn it over with no plugs and listen ... still makes the noise ... then 2. Turn it over with no plugs and the distributor and oil pump drive removed ... noise disappears, you have a solution, noise doesn't disappear you know there is probably a part clearance issue somewhere deeper inside. 3. Only makes the noise with plugs and running ... figure probably combustion related, then.... 4. Check yet again for exhaust manifold leak, crack, exhaust port leak/ crack. No luck .... now you are beyond my knowledge to diagnose. I'd do it all with no belts installed, and AFTER any tuning issues are taken care of. This is not a comment about this particular situation at all, just wondering if that would be the proper assumptions to make in a similar situation. |
#1065
mgarblik,
This motor hasn't run right with this carburetor in Virginia. I had a Street Avenger on it before. This was the carb that was used on the last dyno. Last edited by Va68goat; 08-01-2019 at 07:18 PM. |
#1067
Let's make welfare as hard to get as Veterans benefits! |
#1068
What’s the deal with this engine? He has reached out to me about mine and caster1 engine builder. I gave him the contact info but I know my builder and unless it’s just a simple fix he isn’t gonna cobble it together. He is gonna tear it down and completely redo it using new parts in place of anything he feels is unworthy.
#1069
Any updates?
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
#1070
wbnapier,
No updates...been out of town for a week for work. Jeff and Paul reached out to a guy that lives near me thats going to check out the motor. I spoke to him a few times. Hoping he can come take a look this weekend. |
#1071
Any updates on this????
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135 66 GTO (Retired race car) 421 CID Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
#1072
#1073
Well...I do have an update but I think it would be best to hold off on posting anything until I see how this plays out.
#1074
Hope you boys are able to get a timely, fair and viable resolution to this.
![]() This thread is a close third in all time views in the street section, at 51,000 and counting!
#1075
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
#1076
STEELCITYFIREBIRD,
I'm hoping for that. Steve C., Collusion or conclusion? Hahaha |
#1077
Carnac suggests no secret cooperation or conspiracy, especially in order to cheat or deceive.
#1078
And the results are!!!!
#1079
The results still reside in a mayonnaise jar on Funk & Wagnalls porch..
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
#1080
Was the mayonnaise jar was sealed tight in order to prevent a accidental vacuum leak ?
| Closed Thread |
