Old 09-05-2019, 06:21 PM
Default 75 400 block without a windage tray
I'm having my engine rebuilt for my NO block (XC) in my 75 Trans Am. The block is a 75 and din't come with a windage tray. I bought one from Butler and it didn't fit and after talking to them, they said 40% of post 75 400 blocks didn't come with a windage tray.
Should I not worry about it and build it without one?
Or should I modify one to fit?
Appreciate any input.
Old 09-05-2019, 06:42 PM
John Milner's Avatar
John Milner John Milner is online now
I would not worry about it and just run a good oil pan with a baffle. You should probably also have a main cap that is drilled to bolt down the lower dipstick tube.
Old 09-05-2019, 06:46 PM
thepontiacman's Avatar
thepontiacman thepontiacman is online now
some blocks are not drilled and tapped on the main caps bosses for the windage tray to mount . If bosses are present, they can be drilled and tapped to mount the windage tray.
windage tray has a dipstick tube extension that fits in the windage tray to the dipstick tube in the block, It is different from the tube extension with the strap that bolts to the middle cap.
Your oil pan should have the baffle in the bottom. That's the way it came.
Most early engines had the windage tray and no baffle in the pan.
I'll send you a PM if you want to send me a pic of your main caps from the bottom.
[email protected]
Old 09-05-2019, 09:07 PM
PAUL K's Avatar
PAUL K PAUL K is offline
If you can come up with four studded head bolts that are the correct length, you can use them as main cap bolts. Then drill the corresponding holes in the windage tray and mount it that way.
Go fast, see Elvis!
Old 09-06-2019, 08:37 AM
chiphead's Avatar
chiphead chiphead is offline
Mild performance street applications below 5500 RPM don't really need the windage tray. As others have said, the later stock pan with a baffle will control oil climb and keep oil from sloshing into the rotating assy. Higher RPM (above 5500) would produce more drain back and windage churn in the crankcase, which would require additional oil control measures, like deep pans, windage tray, crank scraper, etc.
Any real racing or g-machine build should have a windage tray, to insure oil control during high RPM, or acceleration or cornering.
Old 09-06-2019, 10:18 AM
OG68 OG68 is offline
Why did Pontiac switch to a 3/4 length tray? Is there any advantage of using the shorter one or was it just a cost cutting measure?
Old 09-06-2019, 12:10 PM
steve25 steve25 is online now
They went that route because the oil pan is so close to the Crank counter weighs up front that the windage exit holes on the full lenght trays are basically blocked off anyway and provide no benefit.
Old 09-06-2019, 10:12 PM
Thanks all for the advice. This car isn't a quarter mile racer and I just want it to run well. I'll go without the windage tray. It has Edelbrock intake and 72 cc D port heads with a Butler grind RAIII cam and Ram Air Restorations exhaust. I guess if I go over 5500 RPM I'll have foamy oil, but it won't happen too often.
Old 09-07-2019, 05:48 AM
A Crank scraper would be the thing to install along with oil pan studs!
