Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 09-23-2019, 09:09 PM
SD421's Avatar
SD421 SD421 is offline
Default Paul “gtofreek” Huge Asset To The Communty
Hey all,
I had some questions recently and called Paul “gtofreek” to discuss.
He is a huge asset to our Pontiac community.
Thanks again Paul!!
Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 09-24-2019, 08:41 PM
Paul is not only one of the nicest guys you'll ever want to meet, he's also a pretty friggin talented engine builder and very gracious with tips and tricks and always willing to help. He's nothing like some engine builders I've met that keep stuff a closely guarded secret.
One of the best I've ever had the privilege of meeting.
Old 09-26-2019, 12:01 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Thank you guys! It's been a pleasure helping you.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
The Following User Says Thank You to gtofreek For This Useful Post:
Old 11-11-2019, 07:30 PM
Paul E Paul E is offline
While I have never had direct business with Paul his help to others on this board is invaluable and has helped me with the information and always spot on to share his knowledge. This was especially helpful in his cam and Hyd roller lifter solutions and direction on different posts. If I did not have other great options he would definitely be on my short list. This board is better because of him and people like him that take there time and support this hobby and the Pontiac community.
Paul
Old 11-16-2019, 03:15 PM
68azbird 68azbird is offline
I have been building and racing Pontiacs for 35 years and have dealt with dozens of machine shops over that period of time. Paul has done all my machine work since i have moved to AZ and i have built 13 pontiac engines that he has done all the machine work on which have never had a problem including my own which has been in my car for the past 10 years.
Paul and Jeff have also built my friends all aluminum 511 inch pontiac which was an abortion from where my friend purchased it from and required months of work to repair all the amateur mistakes.
Lets face it.....most of the machine shops are closing and who will be doing this in another 5 or 10 years.
So why not use the best?
It is easier to fool a man than it is to convince he has been fooled
Old 12-06-2019, 07:53 PM
melemans's Avatar
melemans melemans is offline
Paul is building my little 326 and I have not lost a bit of sleep over it due to any negative comment(s). Just saying there is one loooong story on here that I'm tired of seeing.
Old 12-13-2019, 07:54 AM
P@blo's Avatar
P@blo P@blo is offline
Just because you are tired of seeing this information doesn't mean the problem should not have be brought to light. Not a slam against anyone but I hate when people try to undo wrong by rights they have done. If that's the case if you volunteer for ducks unlimited and are a strong member in your community means you can unrob a bank.
People often have problems understanding this concept but you cannot unrob a bank or unfraud someone, or unassalt them. It's too late after the fact...
Old 12-15-2019, 08:55 AM
Va68goat's Avatar
Va68goat Va68goat is offline
melemans,
Sorry you're tired about seeing the post but it's the truth. I knew it wouldn't be a popular read for some people. Feel free to reach out to me on PM and I can send you my number if you're interested. Good luck with your build. I'm sure it will be fine!
Joe
Old 12-17-2019, 04:08 PM
Va68goat's Avatar
P@blo,
Well put. Believe me, I take no pleasure in bringing any of this to light. I would rather have the money that was taken from me and then promised back to me than having to be forced to go this route. My only advice to anyone that is spending a lot of money on a build, is to document everything, as I did. Save all the texts, emails, receipts, take notes, take a lot of pictures, keep the build on the forum so you can memorialize the entire build and if your states allow it, record any conversations if things start going south. All you have to do is research "one party consent" for your state and also the state of the business you're dealing with. You have to protect yourself.
No matter the reputation of the person that you're dealing with, this should prove that anyone is capable of anything.
Smilies are Off
