Old 10-12-2019, 10:18 AM
JC455 JC455 is offline
Default Log style modular headers
Check out these cool headers- there’s a posting in the Boost/EFI section going on...
http://forums.maxperformanceinc.com/...d.php?t=834392
John
IG: @crawdaddycustoms
Old 10-12-2019, 11:34 AM
AIR RAM AIR RAM is offline
Originally Posted by JC455 View Post
Check this out- modular log style headers. There's a discussion going on in the Boost/EFI section. O ports and D ports...
This is a great opportunity to add a Turbo to just about ANY Pontiac with out the need for welding. These headers are all v-band clamped and have per-fabricated bends that use the same V-bands that offer virtually unlimited options for positioning / and mounting / Adjusting for the ideal turbo placement. The V-bands also offer ease of installation and removal as well as gasket-less leak proof connections when installed.
This option for the Pontiac crowd is a game changer since most Turbo systems need lots of welding which can be expensive if you dont know how to or know someone who can weld.
We are in the middle of a Group purchase for the Round Ports /Ram Air V headers and Stainless Headers is going to make the flanges for a D-Port header. The D-Ports are a tricky design due to the D Ports being so close together...
The method they plan to use to get around that is to use one larger Tube that covers both Ports. Check out the details to the Boosted section in the link JC455 provided if interested.
We have two list going right now... We have a Round Port /Ram Air V head list and a D-Port list... The more we add to the list the greater the discount becomes.
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 10-12-2019, 08:43 PM
Is there a dividerin the Log to isolate 2&4 from 6&8? ( easily done)
Likewise a divider in the Log to isolate 1&5 from 3&7 (can be done)
Old 10-12-2019, 11:02 PM
I will ask this question however from the sounds of this the gains would be minimal... Perhaps I can get Steve on line to answer this directly.
I added your question to the main Tread in the Turbo section.
http://forums.maxperformanceinc.com/...d.php?t=834773
SPEED SAFE, NICK
Old 10-13-2019, 01:13 AM
firechicken's Avatar
firechicken firechicken is offline
It's a log feeding a restriction in the exhaust with no tuned length.
I see very little to gain there.
Old 10-13-2019, 09:30 AM
Look at the Firing Order for EXH pressure pulses charging the Log, AND these pressure pulses go right through the CYL experiencing E/I Overlap.
Old 10-23-2019, 05:32 PM
Just wanted to touch base to let you know that they do have plans to make 2 options for the "D" port guys. One would be without a divider and the other would be a performance version with a divider. The reason they will offer 2 different versions is due to the price difference. The one with the divider will take a considerable more work over the one without and therefor the price will reflect the additional labor.
However the bottom line is, these will be available for the D Ports... If you are racing and running high boost, then the divider will be the best option. If your just street driving with low boost, the header without the divider will cost less and still perform well on the street.
Check out the main thread in the "BOOST" section...
QUICK LINK
SPEED SAFE, NICK
